Upgrading brake lines?
MtnRanger160
Manhattan, KS
Hopefully this isn't sparking old debates, but I feel like I've exhausted researches and can't find a clear answer. Are stainless steel and braided brake hoses worth it? My mechanic says rear drums are well adjusted and have plenty of life but I really don't feel the braking power on these 33's with new rotors like I should.
The hoses won’t change your braking power, but will hold up longer. The stock hoses can degrade over time and cause your brake to stick. I find the $80-100 worth it to upgrade to stainless.
Reactions: MtnRanger160
Stainless steel brake lines won't give you any advantage whatsoever over stock, other than aesthetics, and potentially lasting longer @zip04 mentioned. You will get zero extra performance from stainless steel brake lines as well, that is nothing but myth.
But other than that, it's a waste of money. @mrblaine (the brake expert) can correct me if I'm wrong, but for the most part, the stainless steel brake line thing is pure internet hype.
Despite the bogus claims by some who sell steel braid covered brake hoses, hoses have zero effect on braking performance. Factory brake hoses are reinforced with multiple layers so they absolutely do NOT expand when you apply on the brakes, even when you slam on the brakes.
What is the condition/age of your current hoses, are they original ?
Isn't the stainless steel braid just a protective cover over the rubber? The pressure rating doesn't change. If you need more length, then buy a pair of cheap factory YJ brake hoses.
It sounds like what you really need are some Black Magic Brake pads.
Thanks Jerry, there are definitely many videos and ads that claim otherwise...I'm no expert but the advice you guys give is what I've entrusted in so far and hasn't steered me wrong
Current ones came with a 2.5" lift the previous owner had on which I have no idea how long ago, but they don't look beat up or corroded anywhere
The stock brakes are barely enough for stock size tires (IMHO). If you want better braking, get some Black Magic Brake Pads.
For some perspective, take a look at a back hoe or an excavator. Are the hydraulic hoses rubber or stainless?
To add a little more... while brake lines may look similar to vacuum hoses, windshield washer hose, etc., they're a far cry from simple single layer rubber hoses like those are. The DOT demands they meet very rigid guidelines for strength, ability to withstand expansion under pressure, etc. They do so by being made up of multiple layers that reinforce each other to absolutely prevent expansion under braking system pressures.
Not to mention many aftermarket brake line hoses only slide on their outer stainless steel braiding as decoration, it's not really reinforcing the hose it covers.
Here's one example of a stock brake line hose..
Thanks for being thorough @Jerry Bransford. I don't see problems with my hoses right now so I'll hold off and do some more testing.
Keep in mind a couple things... first, it is the front brakes that provide roughly 75% of the braking. The brake line pressure has to be limited to the rear brakes since they lock up so much more easily during hard braking due to weight transfer away from the rear tires and onto the front tires. Improving the rear brakes is not the way to help braking.
Second, 33" tires have more leverage against the brakes than the smaller factory size tires do so the brakes become less effective as tires get larger. Which is why with larger size tires we consistently recommend upgrading the front brakes with better pads or the a dual-piston braking system upgrade from Black Magic Brakes.
I keep my rear drum brakes adjusted by backing up in a parking lot pumping the e brake lever then again by pumping the pedal only. The pedal feels firm and I can feel they’re working. Black Magic pads would be an improvement I am sure. Oh, I have 33s too.
You can also evaluate your rear drums by how well adjusted the E-brake is. If the E-brake is loose then the shoes are not in adjustment.
Reactions: KCsTJ
In all the rigs I've worked on, I have never had a bad OEM hose. In the same time, I've seen many damaged SS braided hoses simply due to their inability to flex and handle vibration as good as rubber. Given a choice, I use extended rubber when I can find them and the lift height isn't too high. We do use a lot of SS braid lines but only for the sake of convenience in finding the lengths we need and exactly no other reason.
Got bored and started to look up the research on rubber and stainless brake lines. From the sources I found, here is one source used in racing ATV development:
https://www.academia.edu/download/61135250/baja_notes20191105-31615-10nqyae.pdf
I originally used this to calculate out the brake travel on a TJ. However, I did find a photo on RockAuto that shows that the rubber brake hoses are 1/8" diameter, so the formula above do not apply. Also, I do not have any idea on what type of hose was used above. But check out the expansion difference between stainless and rubber.
Here's another source with a quote mentioning a testable difference in expansion rates:
https://www.motortrend.com/how-to/modp-0909-brake-lines-upgrade/
When testing volumetric expansion, Goodridge found that standard OE-type rubber brake hose expanded by 0.136 cc/ft at 1,000 psi, 0.150 cc/ft at 1,500 psi, and 0.290 cc/ft at 2,900 psi, whereas the company's PTFE braided stainless hoses expanded by only 0.0002932 cc/ft at 4,000 psi. The close-to-zero expansion to the braided hose means the brake pedal will feel firmer and will respond more quickly to brake pedal inputs, and if you've done any racing then you'll know that even a split-second faster response from the braking system can mean the difference between slowing enough to make the corner
It appears that the information in that article is sourced from Goodrich:
https://www.thirdgen.org/forums/att...l-typical-gm-goodridge_stainless_v_rubber.pdf
It appears this is a comparison between stainless braid and 1/8" rubber low expansion hose per SAE J1401.
So it looks like there is indeed quite a difference.
But does that difference matter?
Check out the USDOT hydraulic brake hose expansion procedure.
https://www.carsandracingstuff.com/library/nhtsa/TP-106-10.pdf
From page 23:
These tests used by the USDOT are directly from SAE J1401.
So, for example, if we assume that the TJ has 48" (total of all 5 hoses, and a guess, not an actual measured number) of 1/8" low expansion rubber brake line, a 1" diameter master cylinder, and a 8:1 brake pedal to master cylinder travel ratio, that produces a maximum of 0.82" of extra brake pedal travel at 1,000 PSI. That said, I'm assuming 1,000 PSI is a hard stop, and normal brake usage would result in significantly lower travels. (While I haven't explicitly confirmed this, I believe the brake hoses used on the TJ qualify as "low expansion" based on the markings I see in RockAuto photos.)
If we assume that 1,000 PSI correlates with a hard stop, and a normal stop is perhaps 25% the pressure of a hard stop, the difference in brake pedal travel between rubber and stainless will be less than 1/4". So probably not enough to be noticeable, but enough to be measurable.
In addition, SAE J1401 expansion requirements are a maximum, and hose produced with lower expansion than the standard allows is still compliant. In fact, the Goodrich testing above shows that the tested OEM brake lines expanded less than half the maximum amount allowed per SAE J1401. Meaning your "typical stop", brake pedal travel might be decreased by less than 1/8", and panic stop brake pedal travel might be decreased less than 1/2".
In summary:
Stainless brake lines do appear to actually have slightly less expansion at peak pressures. While it may make a small measurable difference, it is unlikely to be a noticeable difference, especially if not all 5 rubber brake hoses are replaced. But for someone willing to go to extreme lengths to minimize brake travel, it does technically make a difference on a measurable scale to replace rubber with stainless.
Most braided lines are Teflon lined, and to be DOT compliant in some states, they need to be covered, the braiding will catch dirt and wear through the lining causing a failure. I build a lot of hoses up to -8 annd 3000 psi range and I don’t make brake hoses because to get legit hose & tooling to build brake lines is cost prohibitive. Go to Eriks and have them made…
I bought my braided/Teflon hoses from Crown. Happy enough with them...I'll take any minor improvements to my brakes that I can get.
I did black hoses...but for the truly stylish ones Crown's hoses are available in different colors. For some that might be all the difference they need.
  • USA Proud
Reactions: hear
From page 23:
In summary:
Well...
Decided to be a guinea pig and try it out. Replaced all 5 hoses with stainless braided, specifically goodridge branded hoses for the three main ones, and Wilwood hoses for the rear axle hoses.
The results?
It actually is fairly noticeable. Not as much in brake pedal travel, but moreso in the firmness of the pedal once the brakes are engaged. The amount of pedal deadband before the brakes engage is pretty much unchanged. But once the brakes are engaged, it doesn't take quite as much movement to modulate the brakes. It's not a particularly large difference, and isn't going to compensate for bigger issues. But it does seem to improve the sensitivity of the pedal.
The only other change that could possibly affect anything I have done would be to flush with DOT4 LV fluid instead of DOT4. (Low viscosity has a very slight improvement in theory; mostly just used it because it was as cheap as regular DOT4.) However, the difference it makes on non-ABS vehicles is nearly immeasurable, so presumably the main difference is the brake lines.
