Tworley build
Sheesh, 3k @ 60mph is STEEP.
On the highway, it'll be about as useful as an Amish Buggy...:ROFLMAO:
5.13s were the correct choice for the AX15 and dana 30 combo. Now that the 32rh is here, I dont want to go thru the trouble of regearing a 3rd time. It helps the jeep is not a daily driver.
I heard crawl ratio isnt a thing on auto. Just swap out to 3.07 and save some gas $$
The jeep is still on jackstands, but I am joining the ever-growing auto swap group on WTJF! I spotted this TJ at the local u-pull&pay and @hosejockey61 graciously picked up the 32rh for me while I was at work.
I still need a few items and have ordered several parts already. Its all very exciting! To make it work with the savvy ua will be a challenge. Savvy never made a skid setup for the early automatics. From my understanding, its going to require a separate, stand alone cross-member as the 32rh is much shorter in lenth. we'll cross that bridge soon enough though.
Hey! Nice score! This will be fun. I always wanted a 32rh. When I initially read your news I thought, “We could swap axles (Revolution 456 for Revolution 513.” Then I looked closer. You’ve got ARB’s and I’ve got PowerTrax and Eaton. Looking forward to seeing this unfold.
Reactions: tworley
My damn pile keeps growing. I've got a lot on my plate this year for the jeep. Going to be fun though
Some more goodies!
Recieved my flex plate stiffener from Team Grand Wagoneer ($14 after shipping) Quality-wise, well it could use some work. It fits the flex plate though.
I haven't. Figure I'll cross that bridge when I get there at a later date
I was going to weld one but am a little bit gunshy after hearing that Blaine prefers to braze them so you don't have to worry about pinhole leaks. We'll see what to do.
Reactions: tworley
If you can weld with a torch, you can braze a bung in a trans pan. Brazing is right there between soldering and welding. I did my own.
Possible issue. I had forgotten about my fan shroud. It broke years ago. I dont think my ram hoses would appreciate being this close.
