Shame on me...why is it we all seem to wait until the last minute to get ready for a trip that occurs the same weekend of each year?
I am leaving for the Rubicon Trail Thursday AM, started going thru the Jeep to make sure all good, packing, etc. Welp, I am now remembering that my rear ARB locker was cycling on and off in SandHollow this past Spring and upon further investigation, I find this:
Rat fuck! I know ARB has a repair kit for this line but no way it gets here in time before I leave for my trip so...I have heard of people soldering the holes in the line in hopes of repairing the leak. In talking to a pal of mine, he suggested using a copper sleeve instead. Great idea!
I ended up buying a small 3/16"OD copper brake line for $8, cut a chunk off of it, had to ream the inside diameter out a little so it would fit over the ARB line and cleaned up the broken line with a tube cutter:
Soldered the sleeve onto both pieces of the airline, reinstalled the line using new fittings from the ARB repair kit I had on hand:
Jacked up rear end, turned on compressor, turned on rear locker and it holds! locker engages and disengages as it should. Now I just need to button up the rear diff, add gear oil and I should be good to go.
For the real fabricators and gurus out there, have you heard of anyone using this technique to repair an airline and it actually works? Or will I be disappointed because it will fail? Lastly, if it does work, should I run it this way until it gives again or should I get a new ARB seal housing kit and make it proper?
