Getting that perfect 50/50 weight distribution now!
Is my Jeep fat?
Is my Jeep fat?
Next substantial weight saving mod is super30&35. And an np231......![]()
And keep finding scales that tell me what I want!
New nicer special hood pins are now installed.
These ones are full stainless steel, including the lynch pins with big serrated flange nuts. Everything about them is nicer in fit and finish.
The grommets are bolted in place for the first time. I used more of the black stainless hardware I have been using on the fenders to help keep the shiny dots down to a minimum.
I spent more time on the pin lengths and positioning. And following Blaine's suggestion, I ground out the grommets where the pins rub on their way through. And I removed the spring and safety latch.
Now the hood will drop onto the pins and fully seat against the bumpers with little to no effort from me. And the lynch pins slide in with just enough resistance to keep the hood snug.
And now I can finally do one last finishing pass on the hood cut, likely with a flat file to remove no more than 1/32" and hopefully eliminate the one small scoop I accidentally made.
So…..halfway done?
Because if I don't do it now, it will never be done- a large part of today was spent shortening and cleaning out the ARB locker wiring harness.
Every round gets more wire wrapped up and put away.
Adding the second wire chase through the firewall helped a lot to keep things from getting too messy. One hole is for the SwitchPros and the fuse block and the other is for everything else.
Halfway done!
