Thanks foe the code! Can confirm $224.25 out the door on holleys site right now. Same price out the door on Amazon as well at the moment.
Mine was the $211.55 price to my door.
Aren't you supposed to be buying cats for an LS?![]()
Anyone install yet on a pre 04?
Those that have installed, how’d the O2 sensors and hardware transfer over? Any issues or do you replace it all during install?
Rich
02s were fine
I chose to use new fasteners since mine looked awful.
The kit is good to go
Mine arrived yesterday. Packaging was questionable but looks to have arrived without damage.
Good to hear. Where’d you source the fasteners? I want to get everything together before I start the install.
Rich
Something like this?If I wanted to connect these two with one of those wide band type clamps instead of the supplied U-bolt, what is the proper term for them to search for one?
Are there any that are better than the others?
https://www.amazon.com/dp/B078TVV4FT?tag=wranglerorg-20
Why not the u-bolt clamp?
Ahh, yes. Thank you.
I like how this is 2 pieces compared to the 1 piece that my jeep came with. I feel like it would be easier to take apart in the future if I'm doing something like removing the oil pan. My experience with U-bolts usually involves dimpling the tubing make it hard to separate. Unless what I've worked on was overtightened or something.
Do those type of clamps require any type of material to seal it? Like an RTV or something. Probably dumb questions, but I've never used anything like them.
