I looked into zinc when I put my stroker in. I’ll cut and paste from a post in my build thread a couple of years back.
“Based on some reading, in the past, minimum ZDDP was standardized by the American Petroleum Institute (API) to around 1200 ppm. This was reduced to 800 ppm in 2004 because higher levels were hard on catalytic converters. The problem is lower levels of ZDDP lead to higher wear on cams with flat tappet lifters. It’s hard to find the exact ZDDP content for a given oil. I use Castrol GTX 10W40 in my TJ (because I always have-no better reason than that). I assume it has around 800 ppm ZDDP, but I may be wrong. If I’m right, my motor should probably have another 500 ppm or so to protect the cam. Lucas TB Zinc plus has 50,000 ppm. So, in 6 quarts (192 oz), 1.92 oz of Lucas TB plus (I rounded up to 2 oz) should add the desired 500 ppm of ZDDP. I realize there are a bunch of assumptions here, so if anyone has hard data to refute this plan, I’m all ears.”
I’m still using the zinc additive and the conventional oil which I change every 3000 miles.
I recall cats being impacts by the increase (normal) ZDDP levels being a cause in the reduction.
My 05 has the mini cats with (under my experience) break apart every 20-50k anyway, so why should I care on cat life... The mini cats don't have a long lifespan in my experience.
In seriousness, I would rather protect the internal and burn out a cat any day!
