you'll end up having to get custom parts for exhaust, A/C, cooling, and then the standalone harness and pcm. if you can't find the vin matching PCM, would you be able to rewrite another or would it be better to get a standalone at that point? if im doing stroker everything is basically plug and play after getting the block and heads bored, polished etc. i'd have to tune for the compression ratio but in term that'd mainly be about it I believe
I've never had any issues running different PCM's but have heard people saying they did.
When I did the first Magnum swap I had to go through 4 PCM's before finding a good one.
The PCM for the Hemi is tuned by Hotwire. I can't tell you what he does to them. You'd need to ask him.
Then because I installed a cam and Eagle heads and larger throttle body FRP wrote me a base tune then I did data logging and he tweaked the tune.
The exhaust you just have to build. You do use radiator hoses from different rigs but have to cut them to fit.
Everything else is just make the lines. It's the same for any of the engines you'd swap in.
If you want a kit with all the stuff figured out for you RedRock 4WD sells one. They have different levels depending on how complete you want.
You're spending money either way. Engine swap or stroker.
You're intended use IMO dictates which way you go.
