Nothing I need, everything I want (2005 TJR, impact orange)
Given that, what’s the benefit of adding the Bartacs in this case? I have no experience with that cover.
Easier than trying to find OEM covers for the stock seats. Easier than finding better condition stock seats. Cheaper than having an upholstery shop rework them. I'm not after pristine, but these were showing some wear and after we swapped in the Summit seat foam, it was evident that they would benefit from a set of good covers. Since I am minor stakeholder in the aesthetic, I took the opportunity to spruce it up a bit with the orange center panels.
Tangent:
What kind of new Dana 44 rear brake wizardry do we have going on here?
I like the stock seats too. Before Summit had the new foam, I had my seats reupholstered and the worn areas of the foam built back up. Is the Summit foam any firmer than stock? I bought new foam for my D3500 from Geno’s a few years ago and they were definitely more supportive than stock (a nice upgrade that really helped on long rides).
But given the above, my question was driven more by the cost of the Bartacs compared to taking another approach.
Lot of things have gotten expensive. I haven't mentioned any of it. The only reason why I mentioned the cost here was the silly 4mo wait time despite the increased costs. It probably would have taken longer if I had not called and said what I did. That said, I understand your question better. The answer is that I wanted something very specific and it simply cost what it did. It also serves another purpose. Often times after hiking and camping I will be a stinky mess and it's nice to be able to clean the seat covers and de-stink them. I had Vinyl covers in the black jeep - they were super easy to clean up but summer time they were not comfortable as wool or cloth seats. The Bartact seat cover material is supposed to breathe better, pretty easy to maintain and it stays looking good for a long time from what I have read on the boards, will def be better than the Vinyl ones in both cold and hot weather.
<snip> Is the Summit foam any firmer than stock? <snip>
Having bought my previous TJ and this TJ used, no way for me to tell if the foam is firmer than stock. Being new, they are firmer than the seats that were in the vehicles after I got them. What I can tell you is they felt very good - firm but comfortable when I briefly sat on them. Note that neither jeep had "bad" seats to start with. You are going to rely on people's memory regarding comparison to new OEM TJ seats, so make of that what you will. I liked them, Blaine liked them and that's good enough for me.
My first impression is they are slightly firmer than stock but it has been a very long time since I sat in new stock seats so that may be the difference.
Reactions: Woodrow
The topic of which is the ideal control arm joint comes up often. "Ideal" is sometimes relative. Johnny Joints have their share of fans and there are also very valid debates about their shortcomings when used in some parts of the country; while they are rebuildable, maintenance is definitely some level of effort (see @Mike_H's threads for details).
After some thoughtful deliberation, for the orange jeep, it was decided move away from the Johnny Joint for this build and go with Clevites. One of Blaine's mantras is to build something with very low maintenance, high durability, and any item that does need maintenance, be very easy to work on. Given my low skill level, the fact that it rains here a lot and there is some mud in the early spring time when I like to get out to explore, that the jeep will see some salted roads in the wintertime when I go snowshoeing and such, Clevites seemed the right choice. Even if one wears it out, press out, press in new, done and back on the road without ever having to take anything apart. No maintenance, joint type does not affect ride quality.
So, we ordered actual Clevites made by Tenneco (Clevite 47855D, Clayton sells them). We looked for joint bodies and discovered that there was no manufacturer that made and sold both RH/LH threaded ones. Synergy only has all left hand threaded shanks and Clayton only has all right hand threaded shanks which is just silly. Nothing was to be found at Teraflex etc. After some time searching, Blaine simply decided to build his own using joint barrels from IRO made with 3/16" wall thickness DOM steel. Weld on threaded studs were ordered from Choppin' Block chassis products. There is some additional detail here regarding the size of the clevites and also the taps that we purchased. Instead of butchering the details with my less than perfect understanding, I will tag @mrblaine to talk about that bit.
After some wizard welding magic that I picture in my head like this (and I am sure I have the wrong type of welding but just run with me here folks) ..
This was the result 🤩
The entire set ..
.. and after Zinc plating. I cannot wait to see them in person.
I told Blaine if he had sent me that picture after plating and asked me to guess where they were from, I would have 100% guessed wrongly as to how they came about. And yes, those clamps for the BMB tie rod and they got plated too. Because Blaine thinks of everything.
And finally this was the result after all the Clevites were pressed in. Jam nuts you see are the "FK Rod Ends" brand that Blaine ordered from Poly Performance. If you look carefully, you will see that Blaine sanded down two flat spots in each of them .. this is so that joint barrel can be supported when replacing the bushing to make removal easier. No detail gets overlooked, nothing is done without very careful and thoughtful deliberation.
I will remember to come back and talk about how long it is before I replace once of these. The technically savvy amongst y'all can argue misalignment and all that fun jazz :) I trust Blaine's word and it's all that I need.
Just don't mention "kevlar" or talk about that utter bullcrap dishonest tabletop misalignment video and we can be friends.
I may be late on this thread but these are amazing works of art
Reactions: psrivats
Nice. Two things immediately come to mind: 1) more space around the console and 2) electric cutting brakes (just need to remember to turn off your locker)
They will be a challenge. The apply function of the controller is based on the current spike to switch off the power. In order to read the spike correctly, the controller has to read both calipers for a total amount of current. That means I'm not yet able to figure out how to do individual sides. But, it is not something I've overlooked, just not there yet.
The main impetus is our inability to find a good rear disc conversion with quality components. This stuff here is top notch for the brake parts and controller side. The brackets are 100% mine so they install without side. They are universal so they can be used to install the caliper fore or aft on the axle with no modification or penalty.
Little under the weather today and was out late for a MOE show in Woodstock. Therefore I had the time to read this thread. This Jeep is awesome and the drive and ability of @mrblaine is amazing. Just wanted to say thanks for what you guys do. Give me ideas and solutions. Love it. 🇺🇸
Reactions: psrivats
There is a very special joy in seeing the pics that Blaine sends that is not easily explained in words. He sent this one over just a short while ago, along with a few others and it made my evening. Some amazing 🪄 work is happening in the rear for storage of several things. I will post pics about that stuff at a later time when the story becomes more complete :)
Was thinking about a net here a few years ago on a Colorado trip,Probably never happen but would love this for a 2002 softop!but this definitely better than a net.
Has anyone done this before for a stellar light source in the back of the Jeep? It pivots, it has a switch and you can't even see the wiring! Lights up the rear perfectly 🙂
(See what I did there?)
