Will a Alpine PDX V-9 fit under the steering column?
Good morning, i am trying to upgrade my stock sound system. Would a PDX V9 that is 13 x 11 x 5 inches amp fit under the steering column? If not where else hidden could i put it? Also what double din dash kit would you recommend? I was looking at this one from crutchfield. Its about $110
https://www.crutchfield.com/S-BVehPwO2Oem/p_120956541/Metra-95-6541-Dash-Kit-Black.html
Yep, I have the bracket and the amp , but it has been ten years or more. Amps still good. Can't remember where I got the under dash bracket but it is especially for the TJ.
Reactions: daylee6003
I’ve been cataloging info from the forums and elsewhere to prepare for my build. From what I’ve read, an amp sized 10.24” W x 7.48” L x 1.97” D will fit under the steering column. Another amp sized 11.9" W x 8.25" L x 2.25” D fit, but it was tight.
Your 13” L & 5” D amp won’t fit in there.
I’m looking at a BLAM RA754D, Kenwood KAC-M3004, or Pioneer GM-DX874 for that spot.
For dash kits… can’t go wrong with Metra.
Reactions: JMT and daylee6003
I have the Kenwood KAC-M3004 in mine and it fits easily under the column. I was able to just use zip ties to hold it in place. So far I have been happy with the performance of it and how it helps to hear music with the top off.
Thank you for passing that information down. I might have to put it under the seat
The Metra DD is great.
That amps dimensions on Crutchfield are different than what you have listed.
  • 10-1/8"W x 2-1/16"H x 8-9/16"D
Am I missing something?
What do you mean that my amp won't fit under there when I just showed you the picture of it installed under there? Do people just ignore even what they see these days and believe what they want? This is crazy. LMAO!!!!
Yeah i am going to try to do my setup like yours. I just have to see if i can find a bracket or have someone make one maybe? Haha what do you recommend for speakers? I wanted to do 5.25 in front and 6 1/2 in the sound bar
Thank you. What place would you recommend instead?,
The rear trunk area or under the front edge of one of the front seats (just out of the way of pesky feet).
I can’t believe I’ve got to do this since this thread is all on one page anyway, but here goes…
I’ll say it again and put it in bold for the cheap seats: Your 13” L & 5” D amp won’t fit in there.
I mean… the forum actually makes it really easy to ignore stuff. They make a button for it and everything.
Please, don't ruin your soundstage by putting 6.5 speakers in the rear. You want the same speakers equally balanced all around for the best soundstage. Then you can tweak your sound stage to perfection by adding a little polyfill behind the front speakers. I spent like thirteen years figuring this out, and it's been over ten years since I got my TJ new in 1997 and set the sound system in 2013. For speakers, I recommend CDT's. They are California made, and 150 watt RMS. These aren't some overseas junk. I have been cranking up my volume on those speakers with my Alpine for over ten years now, and have not blown one out yet. I mean cranking, Dude. lol. I've been cranking those speakers so much that I had to stand 20 feet away from my Jeep to be able to stand it. The CDT's are reasonably priced too, at only $199 a pair, with the crossovers built in. If you don't believe in them, you can get a 5 year warranty for only 10 dollars more. This is how good they are and how much the manufacturer stands behind them. Invest in your sound system, set it and forget it. Of course, if you have an Alpine PDX-V9, you have to have a good subwoofer box, or you are just wasting the potential of the amp. I'm sorry that people continue to run their mouths and don't know what they are talking about, but you saw the picture of it installed under my dash, and the dimensions that you provided were spot on. I checked them. Yes, I recommend that if you are going to this level, that you have a good professional install the amp. There are a lot of wires, and the I went to many installers and they couldn't do it, and install it under my dash. Then, I went to one and he said no problem and gave me a good price. He put that amp under there, and his work was perfect. He has contracts for the City, and does awesome wraps for businesses too. He installed all my lighting, stereo, Alarm system, cables, and power breakers too. And once you find a good installer, it doesn't have to cost you an arm and leg. He installed my head unit with a large screen, back up camera, and hands free mic for $500 total. That was two years ago, and the Android Auto, large screen stereo, is flawless. When the screen suddenly cracked in the corner for no reason, he replaced it and exchanged it for free. The guy is just good and humble. I am lucky that I found him. We still have this kind of quality in this country. And yes, he is Mexican and rich because of his work and attention to detail. Peace out.✌️
Reactions: NashvilleTJ
OP said:
As you said, it’s all in this thread on this page. His listed dimensions for that amp are incorrect. According to your own research the amp will be a tight fit.
CDT does make great drivers for the money, I totally agree. Most modern head units have time correction, you can set maximum delay on the rear speakers to help with the soundstage
Don't install your amp under your front seat. Amps need space to breathe.
Modern class D amps do not generate heat like old school class AB amps, under the seat is just fine. Mine has been mounted upside down to the bottom of my passenger seat frame for probably 15 years with no issues.
