Is the .25 AL your using for your front bumper 6061? If so, your correct, it will crack if bent with too small of a radius.
Yep, I still have the 3582 on the LJ currently. The kits come with a 5431 Precision turbo. It's a 54mm with a T3 flange. The packaging is a little tight with the factory airbox on the kits. If you went much bigger on the turbo the airbox may need to find a new place to live. That 5431 is good for around 500 crank hp that should easily support a mild stroker with low boost. There is also an upgrade for that turbo that adds an additional 85hp.
I know it's tuning dependent but what boost are you seeing on the lj and with your kit on a 4.0l? Estimated(or dyno) stroker hp?
Boost PSI will be up to the set limit, then vented mechanically or electronically, assuming the turbo(s) can flow enough air to reach that limit. Are you asking him how much PSI he is running, or maybe how much that specific turbo is capable with a 4.0?
If you're asking about additional power potential, maybe this can help you out. You can get a really good ball park forced induction power estimate using this equation; (boost psi / local atmospheric psi) X Known engine N/A power = additional power, then add that to the original power amount.
So if you know engine X makes 200 hp at sea level, and you want to push 7 PSI boost and atmospheric pressure is 14.7 PSI, then your power with forced induction will be around 295 hp. (7/14.7) X 200 = 95.24 + 200 = 295.24
I wonder how accurate that equation would be given other variables come into play.
I'm curious what boost he is seeing on his setups and their safe power levels.
Fuel type and availability starts to play a role there as well. In death valley and plenty of other rural places all you can get is 87 octane or severely degraded,old "91".It works, but that is assuming the base number is accurate and not changed, i.e. the forced induction is the only change.
Obviously "safe" power and boost levels vary depending on hardware, but generally N/A engines are considered "safe" up to about 15 PSI, or double the standard power. The 4.0 may be stronger or weaker, but somewhere around 15 PSI I'd start expecting issues in the cylinders. He'll have to answer to give you solid answers since I'm talking in generalities. You piston material and ring gap might be an issue, so that's something to look into.
That sucks. We have 87, 89 and 93 at every station I've ever been to here, and lots of them also have 89 or 93 non-ethanol too. A few stations even have 100 and 105 on a pump, but I live in racing country.
You got E85 out there?
Its economics. No one is going to sell a perishable product that winds up costing them money when the demand isn't there.
Now that is unique and funny!
I need a wiener version of this.
