Will a Dana 30 handle 35s on stock splines with a LS V8?
runninwild
Pennsylvania
Soo my 33s are getting wore down and spikes the interest of 35s...
my question is will a front stock dana 30 with an aussie locker handle 35s Safely? I don't want to loose an axle/ snap something going down the Interstate at 70+ mph shouldn't snap anything just free Wheeling down the highway my worry is a hairline Crack on the shaft or somethning from wheeling and then it decides to catch up with me on the highway...
slight wrench into things... I have a 5.3l ls swapped tj
My Build:
5.3l vortec
4l60e Stage 2 built trans
4.5in short arm lift
Stock np231j t case
Gear ratio 4:10
Rear axle dana 44 w/limited slip
Front axle dana 30 w/ aussie locker
Current tire
33x12.50x15 mastercraft courser mxt
We (family and i) usually do green/blue trails I don't get rowdy with it because with v8 torque something is bound to happen I usually take things pretty easy it's also my daily in the summer. I believe it has alot to do with how you drive if things are going to break I've had quite a few people tell my dana 30 won't hold up to a v8 but it has...
just curious if I should be upgrading to chromoly shafts w/30 spline ?
Chromoly shafts would be a good idea. 30 spline would be better. I don't think I'd be worried about freeway scenarios
My Build:
5.3l vortec
Stock np231j t case
Gear ratio 4:10
Current tire
If you are as easy on the Go pedal as you say then I'd guess no you shouldn't have any issues. The Dana 30's in CJ used to handle V-8 power & 35-36" tires. Won't say they did it No Problem but I've seen a lot of them that lived.
On the flip side I broke stock Dana 30 outers with a 4cy but I did have a 4:1 t-case.
I've also broke 3 R&P in a HP60 rear axle with a Dodge 5.2 Magnum V-8...
But as Rickyd says above if you want to error on the side of caution then YES upgrade your shafts but then that moves your weak point to your R&P...
Reactions: Rickyd
My Build:
5.3l vortec
Stock np231j t case
Gear ratio 4:10
Current tire
Why not stick with higher quality 33" , sounds like the tires aren't holding you back off-road ?
With a stock motor, locked 35s are fine with Dana 30 and up graded shafts (e.g CrMo) and 27 spline works OK. You might be putting 50-100% more torque to the tires with your LS swap. Given that, I wouldn't feel good about mild steel 27 spline shafts even with 33s. So yeah, a super 30 or a Dana 44 would be a better option. Having said that, I know people who get away with bigger tires on smaller axles but they either don't wheel their rigs or are very cautious.
How would you break a front axle shaft in 2wd
Have a Crack in the shaft from wheeling. Not knowing it's there and hit the freeway at 70-80 mph and it decides to show up at the least inconvenient time. Not saying that will happen just something that crosses my mind I tend to analyze things too much sometimes lol
current tire I run hasn't let me down only reason I thought about 35s is there's been a few times I got into a deep rutted section and bottomed out if I'd of had 35s I would of made it only reason I say that is because the jeep in front of me had 35s and didn't have issues. I can air down to about 14 psi and by the time I do that lowers ground clearance only happened twice to me but would like to prevent it if I can
Reactions: ColoJeep
I would imagine if you're gonna break it, you're gonna know right away... Idk if I've ever really heard of what you're describing.
Fwiw I broke a front axle shaft and drove like 4hours home on the highway like that
Reactions: Woodrow
Wait.... You are only airing down to 14PSI off-road? If I'm not in the single digit range I haven't aired down far enough... And YES i used to worry about airing down below 14 PSI.. And yes I didn't have beadlocks.
Yea idk lol like i said I tend to over analyze things too much sometimes... I suppose if its going to snap it's going to do it almost immediately
Reactions: lBasket
When the ujoint caps start rotating in the ears put in chromo shafts ASAP. Spitting a cap and mangling the shafts isn't far bahind
Yea I generally don't wheel hard or push the v8. I more less go on trails here n there do alot of highway miles going to different parks/ rides/ shows
Reactions: Wildman and Woodrow
Then perhaps upgrading your 27 spline shafts to CrMo is a reasonable option. If you do, replace the unit bearings (use Timken) at the same time and save the old units bearing/shaft combos as spares.
Reactions: lBasket
@Woodrow what brand would you recommend for chromoly shafts ?
And why is 27 spline weaker than a 30 ?
Just shaft diameter thicker on a 30 ?
Reactions: Woodrow
