You might be able to DIY the CO2 bottle for your $200 budget. I have the links for DIY’ng someplace. I opted for an ARB under hood compressor because of the small size. Hasn’t let me down yet.
Years ago, I was airing down at a trailhead as a guy in a big mall crawler JK on 35s or 37s was airing back up using a CO2 tank. He decided to complain to me about how awesome his CO2 tank was, but it is only enough for one trail.
I knew this was weird, so I asked him what he airs down to. "25psi," he confidently replies. I tell him that is my normal street pressure, what do you fill up to? "45psi", he confidently replies. I told him that is why your tank only lasts one trail. Also, I air down to 8psi.
He was quiet the next few minutes and drove away on his over-inflated tires.
That sounds more like it. So I would need the tank, a bracket of some sort, a regulator and then fill the tank. How much does it cost at the gas supply to refill the tank?
Yes, I think the reason I have been skeptical about reseating a bead on the trail is that I have had some tough times seating a bead at a tire machine. I think in most of those cases it was a mismatch of tire and wheel size. If things match properly, seating should be easy.
With the 10 pound tank, I can fill my four 40's from 8ish to 25ish three times (meaning 12 tires). Not enough left in the tank at that point to do another complete round of four - if I recall correctly, about enough to fill one or two more tires.
32 tires? I find that hard to believe, but it depends on what pressures at which you start and end.
Yeah, they are not cheap. And for me, I have two fully outfitted 10 lb tanks. I carry one in the trailer to easily swap into the rig after three rounds. I also carry a fully outfitted 20lb tank in the trailer. It does get expensive.
That 32 came from a chart on a website called Power Tank or something like that. I didn’t question its accuracy because I was just looking for a rough answer. I needed to know if it was more like 1 or 100. Also I said “filled,” but they were giving a pressure range like you guys were, not actually filling from empty.
Have you seen the new dual ARB? I've been debating replacing my dual RC compressor with the new ARB. Although it is very hard to spend $1k on it when my RC works great (just for the lockers) and I have a brand new, free RC dual setting on the shelf.
