First of all, thanks for everyone trying to help. I’m going to remove the front driveshaft and send it back to rock auto. I’ll call those driveshaft specialists mentioned, good call on the longest driveshaft thing. I mentioned the thing about the driveshaft because I wanted to know if you guys thought it looked fucked up. It looks like it’s spinning out of itself….
Secondly, I believe that I’m going to get the savvy cable kit and get rid of the stock linkage. I’m hoping this will help me get back into 2WD.
Now, to address Kenneth and Itchydong, the dickwads of the group. I decided to replace the driveshaft because when those caps fall off, that means the shaft needs to be replaced. If I’m wrong, feel free to correct me. Any confusion experienced by you could have easily been alleviated if you would have read everything I have written on here, most importantly my original post. As for you itchydong, why even comment if you aren’t going to add anything constructive or productive?
I was so clear in my posts. I am baffled with how people are confused at all by anything I’ve said. Learn to read.
Thanks again,
Ranger
Thanks again,
Ranger
Thanks again,
Ranger
Thanks for the responses guys. My skins thick, I’m just sticking up for myself!
Yes, the caps I was talking about are the U-joint caps. I didn’t know you could replace that and save the shaft. I’m going to take off the new driveshaft and swap the u joints into my old driveshaft.
I’ll go in and remove the linkage and see if I can shift the transfer case with a tool. Is this lever the one that is closest to the yoke that the front driveshaft connects to? You are not referring to the lever that the arm with the adjustment screw connects to, right?
This is an example pic I found quickly without going through my pics of my NP231 etc.
What his is measuring is connected to the lever I'm referencing. It shifts the internals of the Transfer Case.
You've worked the shifting connection, so you should have seen this, but that short metal shift lever.
On the Front Driveshaft....yes, now we are on the same page, you can replace those U joints. Should be Spicer 1330x on each end.
That Drive Shaft is a "Double Cardan" drive shaft. You may be aware, if not, look that up. That joint in the shaft up by the TC, that can be rebuilt as well if needed. It is also notorious for over age, going out and if it comes apart, and if it blows it will blow your TC too, happened to me when I was pulling it (when my son had the Jeep in College, ha).
Don't worry about that front drive shaft length, that's not causing this issue. The shaft might be a little short but I don't think it's enough to cause any issues and for sure won't affect the shifting of the transfer case.
Do you have a slip yoke eliminator kit and double cardan rear shaft? If so, which slip yoke eliminator do you have installed? There's a large c-clip that holds the rear output bearing into the speedometer housing. Some SYE manufacturers press the bearing into the housing but do not install the c-clip. I've seen it happen a few times that the customer overlooks the c-clip in the instructions and never installs it. This can/will result in the bearing walking out of the housing a bit which will cause improper axial (in and out) alignment inside the case. This in turn causes the transfer case mainshaft (output shaft) to be slightly misaligned which means when the shift collar slides int position it doesn't quite engage with the gears on the shaft properly.
Perfect. Which direction should the lever be pointing once it’s in 2H? Towards the front or rear of the vehicle? Will the 4WD light go off the dash even though I’m manually shifting the tc by hand?
So the caps "fell off" and a new 1310 U joint couldn't be bolted back in because of damage? You don't need a cable shifter or a mechanical linkage to shift the transfer case. Disconnect the linkage, grab the level and pull it towards the front of the vehicle. If you can't shift it by hand then you've got something else going on and a cable shifter, while useful, won't fix it. Heck last weekend we melted the shift cable on @Wildman transmission and took turns crawling under while someone stomped on the brakes to put it into gear. Good luck returning anything to Rock Auto. Pictures would help us offer solutions. -Mac
Listen to the wise OldBuzzard. Shifting the transfer case requires slight rotation of one of the shafts (input or output) to run it through all the positions.
