It just happened!
I've been systematically diagnosing a persistent P0301problem. Today, the issue became apparent upon removal of the fuel rail. The oring for injector #1 was completely disintegrated and plugging the injector. After removing others, I found similar issues, just not as bad. This cheap Chinese junk, and my stupid decision to buy it, is to blame. All the material is cheap, including the supplied orings.
https://www.amazon.com/Racewill-Inj...04-Cherokee/dp/B0D5LC3RMG/?tag=wranglerorg-20
Good on you for digging into that… you should see a real improvement in performance I would imagine
Reactions: Rickyd and Irun
Looking for some counsel here. I've got a buddy who has a very clean 2004 LJ. The hood and fender paint is faded and cracked, but there's no rust.
Jeep Specs:
- 2004 LJ (Light Khaki Metallic Paint) with 123K miles
- Mostly stock
- Full doors (original) and 1/2 doors, fantastic shape but not color matched
- Automatic
- Cruise Control
- Factory Hardtop (with wiring)
- Clean interior, with Bartact seat covers
- New Bedrug, still in box
- No significant rust, with a good frame and body. There's a little surface rust here and there, but nothing that concerns me.
- Lots of parts, including a new Mopar radiator, and more
- Warn front bumper
- New rotors, calipers, and pads (Front are BMB pads)
What the Jeep needs:
- Heater core, which he has the part for (not sure what brand but can check)
- Large evap leak, which I've diagnosed as a broken fitting on the gas tank (fixable)
- Install the cooling system parts
- Replace steering components, i.e. tie rod and drag link
What would I do with it?
Not being morbid here, but my 30+ year old son has been talking about wanting to restore/build a vehicle with me before it's too late. He is the one I gave my TJ to and while he loves that Jeep, I built it, not him. He originally wanted to build something together like a IH Scout, Jeep Commando, or Bronco. However, I've talked him through the practicality and cost of doing that. Coming at it from a different angle, I asked him about restoring an LJ together and he liked the idea.
The catch is I'm not getting this to have a second Jeep for myself. We would work on it together and it would be his vehicle. What that means is he'd have to sell the TJ and drive the LJ as we work on it. That way, I don't have another Jeep sitting in my driveway. The build would basically be a stock (32" tire) refresh, with a few minor tweaks, based on his ideas.
What am I asking for from you?
I'd like to hear your thoughts on this. I am a little concerned about the work to do the heater core, cause I've done one before, but it's doable. In my mind, even with a heater core install, the price is reasonable. Especially given the lack of rust and parts. Thoughts?
  • Love
Jeep Specs:
- Mostly stock
- Automatic
- Cruise Control
- Factory Hardtop (with wiring) & Soft top
- Lots of parts, including a new Mopar radiator, water pump, and more
- Warn front and rear bumpers
- Not installed but goes with the Jeep, two Warn winches (XD and XP)
I'd like to hear your thoughts on this. I am a little concerned about the work to do the heater core, cause I've done one before, but it's doable. As a final note, the price would be somewhere around $11k. In my mind, even with a heater core install, the price is reasonable. Especially given the lack of rust and pile of parts. Thoughts?
What could be more fun than restoring an LJ WITH your son?!
Worked on trimming the Savvy aluminum rocker to fit the Genright fender. I cheated and used a contour tool to get a rough measurement, then used a flap disc to shape the rocker. I'm still debating trimming the bottom corner but I'm very, very happy with the end result. It took a while to get there, which was worth it in the end.
Before the driver side can be called complete, I'll need to figure out how to handle adding the tub "flak" armor. Genright added vents in the latest generation fender, while the flak armor doesn't have the vent (the 3rd picture shows what it currently looks like). It's likely I'll mock it up, draw the hole from the inside, then cut an opening in the flak armor to match the fender opening.
Jeep Specs:
- Mostly stock
- Automatic
- Cruise Control
I'm keeping an eye out for a steal on a TJ/LJ for my boys and I to work on together — and they're 13+ years from driving. So I think you can guess my thoughts ;)
I'm also partial to the color......
Too bad you're not closer, I know a very nice TJ that will be up for sale! ;)
Don't temp me - not too far.... Good looking Jeep!
But I'm in the same boat as your son - I'll be looking for one I can work on with my twins to build up and build memories. That one looks like a great buy for someone looking to hit the trails now - lots of good upgrades from just those couple pics!
I built this one with the intent to make it a "sleeper". The idea was to take what I'd learned, or thought I'd learned, keeping the tire size to a maximum of 31" to 32". This forum provided invaluable input, to make it a Jeep that shocked many of my friends. I've wheeled it on some of the more challenging trails in our area and was only denied on a fraction of them. It's great on the road and excels offroad. I have over 600 hours in it, and it was truly a labor of love!
https://wranglertjforum.com/threads/a-lesson-learned—keep-it-light-and-nimble.44924/
