See post 760. More to comeDid the spring show up yet?
If an 8 year old can tell a difference and then say, that feels beefy...lol I bout split a gut... I'm sold on the locker!Update: tiny spring for my PowerTrax No Slip came in this morning. Of course, I was at work and had an MTB ride at 6pm and I needed a 13mm 12 pt socket to tighten down my axle retaining bolts to 75 ft/lbs. So I raced to Ace at 4:15, then drove home way out in the country, changed clothes, grabbed the spring and some grease, shoved that puppy in, did the turn simulation test, it worked perfect so I put the RTV on the diff cover, waited 10 minutes for it to become tacky and tightened down the axle retaining bolts to 75 ft lbs, got hte diff cover on and hand tightened the 10 bolts, then tightened them down, and lastly torqued to 28ft lbs, started pouring the 80w-90 gear fluid into the fill hole, it takes 1.25 qts, plugged it, torqued down to about 25f lbs and took it for a spin. WE live out the country, long gravel drive. I’m trying to get on the road for my MTB run and we’re trying to eat first, so mind you, I didn’t get home till 4:35 and we’re leaving at 5:20 to go eat. In 2wd it’s like the same Jeep I always drove, absolute dream on turns, straights, it doesn’t matter, I put it in 4wd low, man did that ever change things, I have never felt anything like that in my life, my 8 year old daughter said, “Dad that feels beefy.” Uh, yeah, it does, the steering is different, I’m going to have to practice, but you can tell just going into 4wd that this thing is a true beast now. Lockers are the bomb. Best mod I ever did to my Jeep, hands down. I can’t wait to get this thing on the trail. I’ll take it around our property tomorrow, we have a ledge and a few climbs. Thanks @Jerry Bransford for suggesting this mod and clarifying the terrain and instances and climate these lockers would excel in. Thanks @Rob5589 for some clarifications and torque specs for the Dana 30 axle. Thanks @KCsTJ for encouraging me. Thanks @b0xcar for being my number one wheelin buddy and talking mods out and just being a friend!
I ran 31's the first 5 years of jeep ownership, and wish I would have stayed with that size, just saying.
Why? The Jeep I am looking at has brand new, aggressive tread 31" tires. It will be my daily driver and I plan to off road at least once a month on trails and rock crawling. I love the look of 33" and feel they will be better off road (judging by my wife's Jeep). Can you tell me why you regretted your decision?
WOW... I have so much to learn :/
I never thought 2"s of tire could make for that much work. OK, you present a very good argument for leaving it at 31" for now because I am not in any way ready to do all of that other stuff right when I buy it. You note a 2.5" lift with 31" is what you had yet you mention that at 2.5" and above you get drive line vibes. Did you get those when you were running the 31" tires and 2.5" lift?
If I buy this, leave the 31" tires on it (they are 31" x 10"), put no more than 2.5" lift on it why would I need to replace my tie rod?
I do plan on some rock crawling so the under armor sounds like a simpler solution however I do like the look and feel of an aggressive lift. Maybe one day, I need to start somewhere and I think this LJ I'm going to look at is a great start.
The stock TJ tie rod is just wimpy. It’s a narrow, hollow tube. I you’re going to be playing in the rocks the ZJ tie rod is a very good mod. I’ve seen stock tie rods bend on the trail just hitting one rock (and I’ve only been wheelin a little over a year).WOW... I have so much to learn :/
This is what I would do. You'll hear a lot of us say (myself included) that if we could have done it all over again, we would have just stuck with 31" tires and a high quality, small lift, such as the 2.5" OME lift.
I realized after I did 33" tires, that I absolutely do not need them at all. It's way too much for the sort of stuff I do with my Jeep.
You are the second guy to say this. I LOVE the look of your ride on 33s but I am hearing over and over again about how much other stuff is involved with getting 33s to be setup right. I do like the idea of more ground clearance but the reality is you are literally gaining only 1" of ground clearance for a heck of a lot of work.
Yeah, but look how good they look!
Go ahead, drink the kool aid brah............DRINK IT!!!
Come on @JMT, your shameless poser pick might send him over the edge, lol!
STOP IT PLEASE STOP!!!!!! I LOVE that look, that's it, that IS the look. Great now I have to be patient and first buy a jeep and then get it to this point.
OK so we have established this is the look I want. This will be a daily driver for me and it will see off roading. Can you please tell me exactly what parts you put on to achieve this? Also I will most likely be doing this to an LJ. any chance you got a pic laying around of an LJ with this setup? To me what you have done is a very classic look on steroids and I dig that. That is one thing I like about the TJ. The LJ has so many things going for it but you lose a bit of that classic look. There are pros and cons each way. I eagerly await your diligent, detailed reply to my question![]()
Glad I'm around for the journey. You are doing some great things with your Jeep. I've been impressed with what you have been able to accomplish. I like how you have a well thought out plan for everything you do. Just with this post you have me rethinking what I want to do with mine. Can't wait to see your rig perform in Oct!Update: tiny spring for my PowerTrax No Slip came in this morning. Of course, I was at work and had an MTB ride at 6pm and I needed a 13mm 12 pt socket to tighten down my axle retaining bolts to 75 ft/lbs. So I raced to Ace at 4:15, then drove home way out in the country, changed clothes, grabbed the spring and some grease, shoved that puppy in, did the turn simulation test, it worked perfect so I put the RTV on the diff cover, waited 10 minutes for it to become tacky and tightened down the axle retaining bolts to 75 ft lbs, got hte diff cover on and hand tightened the 10 bolts, then tightened them down, and lastly torqued to 28ft lbs, started pouring the 80w-90 gear fluid into the fill hole, it takes 1.25 qts, plugged it, torqued down to about 25f lbs and took it for a spin. WE live out the country, long gravel drive. I’m trying to get on the road for my MTB run and we’re trying to eat first, so mind you, I didn’t get home till 4:35 and we’re leaving at 5:20 to go eat. In 2wd it’s like the same Jeep I always drove, absolute dream on turns, straights, it doesn’t matter, I put it in 4wd low, man did that ever change things, I have never felt anything like that in my life, my 8 year old daughter said, “Dad that feels beefy.” Uh, yeah, it does, the steering is different, I’m going to have to practice, but you can tell just going into 4wd that this thing is a true beast now. Lockers are the bomb. Best mod I ever did to my Jeep, hands down. I can’t wait to get this thing on the trail. I’ll take it around our property tomorrow, we have a ledge and a few climbs. Thanks @Jerry Bransford for suggesting this mod and clarifying the terrain and instances and climate these lockers would excel in. Thanks @Rob5589 for some clarifications and torque specs for the Dana 30 axle. Thanks @KCsTJ for encouraging me. Thanks @b0xcar for being my number one wheelin buddy and talking mods out and just being a friend!
I'm referring to the ground clearance of the axle. Obviously the suspension and body lift that come along with putting 33s on give you more clearance of the underside.
It is invisible in 2WD, when you go to 4H it engages and stays engaged if you shift to 4L. You do NOT need to get on it to induce slip for it to engageWait... so the locker you put in, the PowerTrax No Slip, is an automatic locker that you didn't notice in 4H but as you mentioned as soon as you dropped into 4Low you felt the locker kick in. Is that true or did you need to get on it or try to induce slip to get it to engage?
Just to derail the thread a bit more...2" spring, 1.25 body lift, 33'sSTOP IT PLEASE STOP!!!!!! I LOVE that look, that's it, that IS the look. Great now I have to be patient and first buy a jeep and then get it to this point.
Everyone on here used to say, stay at 31’s, stay at 31’s. I never bought it, partially because @bobthetj03 said, go wheel in your area and see what kind of rigs are there, see what kind of terrain it is, and build for that. But I was warned, repeatedly, ad naseum, to stick with 31’s. It is easier, it is cheaper, there is no doubt about that, but it is not as fun and it does not look as good as 33’s.Yeah, but look how good they look!
