That doesn't look like an odb2 code number, I've never see that description before ether.
No chance you could epoxy or plastic weld the leak? I've done plastic welding on a few things with a temp controlled soldering iron and the right filler material. (up here princess auto sells the plastic filler rods, so probably HF would have em there) I've also used zip ties in a pinch as filler.
There must have been a time
when we could have said no.
