I have mostly settled on my build road map
Neil Sears
Big Bear, CA
Hi All,
As the title suggests I have a road map that I am good with as a starting point. There are a few DIY projects that I will need to take on but I feel everything is doable by spring.
There are two option for tire size that I am still deciding on.
Please forgive the hack photoshop job (shown with the 33” option) but it gives you an idea where I’m heading.
SUSPENSION (33.1” Option)
Old Man EMU - 2.25” Lift
Savvy - 1.25” Body Lift
JKS - 1" MML
TJ - Moab 16” Wheels
DuraTrac - 285/75R/16 (Load Range E) Tires (deflated to 26 psi off-road)
ARB - 12V Twin Air Compressor
ARB - EZ Deflator
Or
SUSPENSION (31.7” Option)
DuraTrac - 265/75R/16 (Load Range C)
BODY
TJ - Rubicon Diamond Rock Guards
Smittybilt - SRC Rocker Guards
Smittybilt - SRC Roof Rack
Bushwacker - 6” Flat Flares
TJ - 03” Mirrors (relocated to window frame)
TBD - Halo Headlights
INTERIOR
Tuffy - Center Consol
Best Tops - Instatrunk
Smittybilt - Hand Grips
Smittybilt - Cargo Net
TBD - 2 pc Hard Top
DIY
JK - Front Turn Signals (mounted in grill)
Diamond fender armor (blocking out TJ turn signals)
Diamond rear quarter armor
Smittybilt Style front bumper (with built on winch cover)
Reactions: JMT and psrivats
Just did the VIN# look-up:
VIN 1J4FA49S8YP727788
Vehicle Description:
2000 JEEP WRANGLER SPORT 4X4 SPORT UTILITY 2-DR
STANDARD EQUIPMENT
  • * Monotone Paint
  • * Power Front Disc/Rear Drum Brakes
  • * Reclining Front Seats
  • * Rear Folding Seat
  • * Next Generation Front Air Bags**
  • * Passenger Air Bag On/Off Switch
  • * Front Seat Area Carpet
  • * Rear Seat/Wheelhouse/Cargo Carpet
  • * Cargo Tie Down Loops
  • * Sport Bar w/Rear Padding
  • * 3-Spd. Automatic 32RH Transmission
  • * Command-Trac Part Time 4WD System
  • * Dana 30/186MM Front Axle
  • * Dana M35/194MM Rear Axle
  • * Tinted Windshield Glass
  • * Swing-Away Mirrors
  • * Instrument Cluster w/Tach
  • * 100 MPH Primary Speedometer
  • * Cigar Lighter
  • * Dual Note Electric Horns
  • * 12V Auxiliary Power Outlet
  • * Locking Glove Box
  • * Lt. Quartz - Badge - Sport, Cowl Sid
  • * Lt. Quartz - Badge - Jeep, Lower Cow
  • * Lt. Quartz - Badge - Wrangler
  • * BLack - Fender Flares, Black
  • * Halogen Headlamps
  • * CHMSL Lamp
  • * Black Front Bumper
  • * Black Rear Bumper
  • * Bumper Extensions
  • * Chrome Headlamp Bezels
  • * Black Front Frame Overlay
  • * Body Color Grille
  • * Sport Bar w/Side Padding
  • * EVAP Control System
  • * 19 Gallon Fuel Tank
  • * Black Clear Coat
  • * AM/FM Cassette Radio
  • * 4 Speakers
  • * Power Steering
  • * Normal Duty Suspension
  • * Front Stabilizer Bar
  • * Rear Stabilizer Bar
  • * Outside Tire Carrier
  • * P215/75R15 RBL Wrangler AT Tires
  • * Goodyear Brand Tires
  • * 15X7.0 Full-Face Steel Wheels
  • * Upgraded OBD-II Connectors
  • * Fuel Tank Skid Plate Shield
  • * Transfer Case Skid Plate Shield
  • * Tethered Fuel Filler Cap
  • * Protective Coating and Remover
  • * Build To U.S. Mkt. Specifications
  • * GVW Rating - 4450#
  • * U.S. Fleet Purchase
  • * Zone 51-Chicago
  • * U.S. Specifications Label
  • * California Ship to State Code
  • * Texas Sold to State Code
OPTIONAL EQUIPMENT
  • * Vinyl High-Back Bucket Seats
  • * Camel
  • * Steering Group
  • * Convenience Group
  • * Heavy Duty Electrical Group
  • * 4.0L Engine(ERH)/3Spd Auto Trans(DGG
  • * 117 Amp Alternator
  • * 600 Amp Maintenance Free Battery
  • * High Back Bucket Seats
  • * Front Floor Mats
  • * Full Length Floor Console
  • * All 3-Speed Automatic Transmissions
  • * Lock-Up Torque Converter
  • * 3.07 Rear Axle Ratio
  • * All Engines
  • * 4.0L I6 Power Tech Engine
  • * Light Tint Front Door Windows
  • * Full Metal Doors w/Roll-up Windows
  • * Left Manual Mirror
  • * Right Manual Mirror
  • * All Vehicles W/O Power Mirrors
  • * Air Conditioning
  • * Var Intermittent Windshield Wipers
  • * Lt. Quartz - Badge - 4.0L
  • * Courtesy Lamps
  • * Underhood Lamp
  • * California Emissions
  • * Low Emission Vehicle (LEV)
  • * Speed Control
  • * All Radio Equipped Vehicles
  • * Fixed Long Mast Antenna
  • * Leather Wrapped Steering Wheel
  • * Tilt Steering Column
  • * Full Size Spare Tire
  • * Dark Tan Soft Top
  • * Matching Spare Wheel
  • * All Steel Wheels
  • * Manuf Statement of Origin
  • * 5 Additional Gallons of Gas
  • * Spring - Left Rear
  • * Spring - Left Front
  • * Spring - Right Rear
  • * Spring - Right Front
  • * Customer Preferred Package 2TD
  • * Customer Preferred Package 24D
  • * Price Protection - Code J
  • * Delete Group Funds-Fleet
  • * Customer Preferred Discount
  • * Sold Vehicle
  • * Fleet Option Editor
  • * Fleet Sales Order
  • * Dealer Fleet
  • * City Capital Fleet
  • * Fleet Matching System
  • * Status D to D1 Less 100%
  • * Paint Order Code
3.07 gears... oh man, those have to go. Literally the worst gear ratio offered ;)
New gearing will happen when I do the lift:
As of now:
OME 2.25” SL
Savvy 1.25” BL
JKS 1" MML
Goodyear Duratrac 285/75R/16
I think I'm holding off on Discos or Antirock at this time.
Also as i'm planning the MML I will not be doing a TCD
Reactions: JMT and Chris
That tire is designed to carry up to 3750 pounds per tire. As such, it's heavier, and has more tire plys to carry the load - making it not very compliant for bumps or able to conform to rocks, terrain, etc.
Something load range C is much better for our weight Jeeps. Unfortunately, that usually means a 15" wheel, or a more rare tire in 17" wheel diameter.
Reactions: Neil Sears
Not many, if any C options left in 16 inch wheels. I’m on the same tires your looking at now and they ride nice, aired down to about 26 pounds each.
If/when I replace these tires I’ll be getting a set of 15 inch wheels and C Rated tires just so I can have real life comparison.
A few really good forum posts here on the difference in sidewall ratings between Cs, Ds and Es.
Thanks.
How rare?
What 33” inch tires are out there with a “C”?
You’re problem is the 16” Moab wheels. That’s a weird size rim. I know Jeep did it, but it is. You’re tire options drop severely. Try a similar 15” wheel, something like the Quadratec Rubicon or Mammoth Boulder’s. Then your tire choices skyrocket
I see now why some threads I have read dropped the Moab’s mid build!
As I will be driving to my destination (often hundreds of miles away) or going to our mountain cabin (that gets snow in the winter) the DuraTrac’s are actually a good fit for me because they do both of those things well.
When I’m done with this build I have a feeling I’ll get a Rubicon and on that I’ll put a better wheel size.
Although nothing is written in stone 😎
Yep, those will work. I had a set in 31’s. Now I run Cooper STT Pro’s in 33x12.5
Ask around about the MTR and snow before buying them. I seem to recall the two not playing well togther.
