When I was putting on a body lift (I was wanting to go taller, not shorter) I also replaced my body mounts too. I got the Crown rubber body mount set. My original ones were not as worn as yours, but they were pretty rigid after 21 years of life.You are sure correct on the body mounts weathered. I will get those out and learn about bump stop setting. Those rc shocks are rough.
I changed a bunch of other stuff so I don’t know if I can feel a difference due to the new mounts. But since I was already doing the other work, I figured the extra $100 was worth it for the future.
A few things to keep in mind:At least these are going to be pretty easy because the body lift is fairly recent. I appreciate your reply and think I will get the Crown set ordered.
Different kits do it differently. That looks like it’s part of the body lift.View attachment 64904
Is the bolt-on bracket under the cushion part of the body lift?
Kind of sinks the idea of removing the 1.5 body lift and leave the 4” suspension doesn’t it?Yes that's an MML.
I think all that would need to be done is to reposition the fan shroud.Kind of sinks the idea of removing the 1.5 body lift and leave the 4” suspension doesn’t it?
Would that actually work?I think all that would need to be done is to reposition the fan shroud.
Possibly 2 to 2.5 ? The body spacers are about 1.5 in length. The way they sit in the mount well, is all that lift?I would lean towards reducing the spring lift.
2.5 plus the body lift?2.5-3" with the body lift. My standard recommendation is to do what it takes to maintain a minimum of factory 4" of suspension up travel.
Correct. In addition to...[
If I go with teraflex springs
If I go with a 2.5 lift on my tj, I will probably end up with rough country springs. In teraflex my choices are 2 inch or 3 inch forCorrect. In addition to...![]()
a TJ. I think OME is the same. My body lift is 1.25. With the BL would the 2 inch be cutting it too close on my 33s.
