2-3X greater low-end torque, infinitely low first-gear ratio, and better/easier control on extremely difficult trails. All thanks to the magic of the automatic's torque converter. :)
I know the arguments but would love NV 4500 or a strong 6 speed behind mine. :(
Your '99 has a distributor, the 4.0L went distributorless in 2000-2001 so it'd probably be safer to stick with a 97 to 99. I installed a '99 into my '97 and it worked ok so they're likely mostly compatible but I'd be wary of it if it came off one of the newer distributorless 4.0L engines.
Reactions: macox49 and Bryan
There are two sets of bolts you need at the back of the motor. The first set is the flex plate to flywheel place bolts. They are lower profile but not what you would consider low profile and you can't substitute normal grade 8 bolts for two reasons. The first is the oddball length and the second is they are place bolts with a special head configuration to prevent loosening when torqued correctly.
The second set of bolts holds the torque convertor to the flex plate and they need to be the ones designed for that application as well for similar reasons.
As far as the wiring goes, you may or may not have the short adapter to hook up the harness for the NSS and TCC switch for lock up.
The 2002 need to have the harness from Vintage Parts purchased and used. It will plug into the adapter harness that the reverse light switch plugs into for the manual. Other years just have the correct harness folded back and taped in place.
You will also need the firewall block off plate for the clutch slave and master. Don't get sucked into the higher prices on Ebay, it is about a 10 dollar part at the dealer.
For the center console, you will need the auto shifter floor plate for the auto and the shift indicator bezel. The bulb holder is taped back along the harness under there and a 194 bulb will need to be plugged into it and then stuffed into the bottom of the bezel to light up the selector when the dash lights are on.
The auto shifter can be had at the dealer or Davey's and you will need a new shifter cable. The one from a Cherokee will work but I don't recommend it. The TJ version has a section of heat wrap on it where it goes by the exhaust manifold and the XJ version doesn't which cooks the cable housing and then it will break.
A TV or kick down cable will need to be installed. When you install it, you also remove the return helper spring from the throttle body lever and discard it. The TV cable has a spring on it at the trans bracket.
When you install the new trans mount, you will need the square adapter plate that bolts to the trans skid. The bolt holes are there and use carriage bolts pointed up with the nuts on top. It mounts over the other set of holes in the skid that the manual mount is not using.
The actual trans mount is the same but the adapter plates that bolt it up to the trans are different between the two.
The t-case shifter needs to match the one from the trans due to the different lengths. The 32 is the shortest trans Jeep used in the 6 cylinder TJ's so the t-case is further forward which also makes the front driveshaft short and the rear longer. The t-case bell crank tub side bracket is the same and the difference is made up with the bracket on the trans and the two linkage rods.
The bolts that hold the trans to the block are not the same as what holds the manual to the block and you need the motor plate with inspection cover for the plate.
It may have been mentioned but I skimmed a lot of it, but use ONLY a Mopar radiator with the auto trans cooler built into it. If it hasn't been done in awhile, now is a good time to do a flush and get some new coolant in there while you are doing the radiator swap.
The absolute hardest part of the swap is loosening the exhaust so you can snake the cooler lines between it and the oil pan. Try not to cobble together the cooler lines and only use OEM if possible. There is a check valve in one of them that prevents torque convertor drain back which delays the shift into gear after it sits overnight.
If you don't locate a PCM in time before the swap is complete, you can run it with the manual PCM. It will throw a CEL at key on start position due to not seeing the TCC lock-up circuit. It will run well enough to test the trans. Don't run it like that for long as the CEL will stay on and it may need to be on for something else that is more important that you won't know about.
The trans requires ATF+4 fluid and roughly 10-12 quarts of it. Now is a good time to do a deep pan swap and replace the grommet at the base of the dipstick tube where it enters the trans. They tend to dry out if the trans has been sitting and will weep. If you notice any holes in the trans where the pan bolts up that are a bit wonky, I have some Timeserts I use to fix them. They tend to strip out very easily in the cast aluminum. Use the re-useable pan gasket that is the hard plastic with the raised ribs. They work perfectly every time and are worth the money. The deep pan uses a drop down extension for the filter so don't get a deep pan kit without one. While you have the pan off, weld a bung in it for a temp sensor and run a temp gauge. You will or should use a small cooler in front of the radiator to aid with cooling the auto and plumb it in series with the return to the trans from the OEM radiator.
can you get your pcm flashed at dealer to work with auto trans ?
I'm new to the forum and was told to look on here. So here I am lol. Looking for someone that has swap manual transmission to the automatic 32rh transmission. I just bought the 32rh and needing a detailed write up on it. I was also told that a guy named @Jerry Bransford has done this before so hopping to find him. Thanks
what year is your tj and what year is donor trans?
Possibly but TJs are old enough that some dealers may not have the means to do it any more. If they can they'd likely charge more $$$ than would be moral. An easier/cheaper source can be found on places like eBay. There are a number of shops around that repair and/reprogram PCMs. Amazon.com may have them listed too by now.
My tj is a 99 and the transmission not sure of the yr that it came out of. It's all in and working for a while now. Like Jerry said about the computer don't think the dealer will and I found my computer from a local guy that has a ton of jeep parts.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Reactions: macox49
Any dealer or dealers in general? I'm not aware of any dealer that can reprogram one to convert it from one trans to the other. That is generally done by specialty companies, not dealerships.
getting ready to do this swap myself as all I do anymore is rock crawling anymore with my trailer queen .yea wasn't sure about pcm thanks. my doner trans is out of a 99 tj and my tj is 2001.i read what you wrote about the distributer stuff.hmmm will mine work? I have every thing from a guy that did the auto to manual thing lines bolts plate shifter stuff..also I was wondering about the difference in the transfer case shafts or does that extentened seal fix this...trying to line up all my ducks to go smoothly..lol damn you guys got some good info thanks in advance ... I love this site
just when I thought I touched or fixed every bolt nut seal on my tj.a new mod or idea to make this little jeep go just about anywhere and I'm still learning. I think the learning part is half the fun
Even though I got mine because my hands just can't take the shifting anymore - I would have bought my current Jeep with the auto anyway... Exactly because of these things!
The low low first gear, and the ease of driving *really crappy* sections like rocks etc. made it worthwhile to me.
I got really tired of clutches in the rocks ;)
I know this is a little old, but it pertains to my issues. I just did this swap from the ax-15 to the 32rh, I got it to run and drive, but after it is warm i get a very loud clicking from the torque converter bolts hitting the bell housing/inspection cover only when warm. It drove fine when warm in 1 and 2, BUT the clicking came back and i wasnt able to use Reverse or drive, only 1 or 2 to get it home. When the clicking first started it was acting very sluggish. Something else i believe is related to my problem is when put in reverse or drive, it seemed like the idle was higher, it reversed at idle faster than im normally used to. Any help would be greatly appreciated as i have plenty of experience with manual, and no experience what so ever with automatics. BTW my TCC solenoid plug was boogered up so i havent plugged it in.
Did you use the special very low profile bolts to attach the torque converter to the flex plate? They have a reduced bolt head height to give enough clearance to the torque converter.
Yes, I had everything sourced from an automatic wrangler same year and all, told the guy i needed all the hardware and everything. while in park or neutral, there isnt any noise, only in drive and reverse and after driving a bit in 1 or 2
Could my Torque Converter be locked up? could my flexplate or TC be damaged? I can drive it with no issues when cold. Also, when put in reverse, with the brake pressed hard, it stalls out. Could this deal with the TV cable? I thought getting it in went too smooth. And again I appreciate any help. Thanks.
Exactly what adapter do I need from Vintage Parts? I’m currently doing the swap on an 02 and the TC lock up wires are nowhere in sight.
There is a short adapter harness that goes from where the manual trans reverse light harness connects to the harness to the rear. You need that one.
I can’t find the adapter on Vintage Parts. But on all of the factory Chrysler/mopar sites it says the part is discontinued.
Old thread but hoping for some thoughts. While not quite ready for a swap yet, my left knee has arthritis and it is aggravated from shifting…not enough to stop me, and hopefully not for a long time, but since I plan to have my TJ until I die, there will come a point when I want to do a automatic swap.
My question is reference to the transfer case and if I will need to change that. I have the atlas four speed with the double low of 10.8:1, which is incredible in the manual, and the range of gear choices is awesome…but it drives right through the brakes, so it’s a clutch brake combo…as gas pedal not needed at all! I did see the automatic is actually a 1/2 inch shorter so I don’t think length is a problem, but without a clutch, will the double low in an automatic drive through the brakes as well? I saw some talk of people having issues (but seemed like wrong torque converter) with just the rubicon 4:1 ratio, so that concerns me.
If I do have issues, could I just slip back and forth between neutral and drive kind of like I do with the manual, or is that bad on the auto?
Finally, should I get parts now or are they likely always going to be available? Some of the items concern me more than others, so thinking of just getting everything now and then when I decide to do it I’ll be ready.
Thanks!
Big
Thanks!
brake kit
