Sorry glwoodI was really looking forward to these photos, but without stock flares, they don't help in my case. The flat flares have so much more room it's hard to see what it would look like without those.
Thanks for posting, though.
It definitely looks like more than a 2” lift with the flat fender flares. Going from the bushwhackerstyle to these it definitely gave me more clearance.Sorry glwood![]()
The spring is marked with 309 and the instructions say the PN is 034309RIs there a part number on the spring you can check? Maybe you some how got a 4" kit.
These are the 3” numbersDid you happen to measure the springs before you installed them? I'd be interested in knowing the length of them. If the 3" are anything like the 2" the spring rates are higher than stock to help compensate for jeeps with aftermarket steel bumpers, tire carriers, later spare tire, winch, armor etc. If your Jeep is stock it will likely sit higher than the advertised lift height due to the lack of weight to help compress the initial coils to their designed sag (ride level) point.
JKS told me their 2" springs have the following specs
JKS 2" Front - 150/220 lbf/in - 19"
JKS 2" Rear - 190/240 lbf/in - 14"
What would be interesting to know know is if the length of the 3" springs are 1" more than the 2" 20"/15" or if they are not then they likely just increased the spring rate to help hold the jeep higher up. I do really wish someone would make a true progressive 2" spring.
Look forward to seeing your jeep on all 4. Do like that color.
Bushings with rolled steel center sleeves are slightly elongated and tend to move on the bolt . Same issue with rough country track bar bushings.I just skimmed through all 7 pages and a lot of you got more involved researching spring rates that what I did. And maybe I should have!
I'm currently in the middle of installing the 3" JKS JSpec on my 05 Rubicon. So far I have the back finished and working on the front half now. Right now with the rear on the ground its measuring 4.25" of lift rather than 3". I'm a little worried about this as I really wanted this dialed in at 3". Ill have to finish before anything is official. I purchased 33x10.5x15 BFG KM3's and I'm worried I should have just went with 35's if its going to be a 4" lift. If this ends up being a 4" lift in the end Ill be reaching out to JKS to see if I can switch to the 2" springs using all the same parts that came with the 3" kit. Likely the answer is yes.
It is a quality kit. The control arms, track bar, and brackets are all beefy. I added fixed lower control arms, and adjustable upper front control arms. I'm also using the JSpec shocks. I had myself sold on a Rock Krawler X Factor kit, until I was talking to Verne Simons (journalist for Petersons 4wheel mag). He sold me on the idea of using all JKS control arms and track bar with a different brand spring (I can't remember what he said to go with). But now I wish I remembered because I might be swapping springs until I find something I like. But again, too early to say yet since I'm not done. I figured I would just start with all JKS since the kit is so complete.
My TJ still has the factory bumpers so its on the light end. I'll probably never put on those bulky heavy bumpers as I don't like the look. Ill be sticking with stronger classic style bumpers like what Warn or Pro Comp sell. View attachment 92191View attachment 92192View attachment 92193View attachment 92194Ill update when I'm done.
Been noticing some clunking coming from the rear lately over certain road undulations...think it could be my RC track bar for the reason listed above?Bushings with rolled steel center sleeves are slightly elongated and tend to move on the bolt . Same issue with rough country track bar bushings.
Well I had it going on with mine and the rough country track bar accepted the stock replacement bushing...the rough country bushings were made in Mexico and the rubber was extremely soft.Been noticing some clunking coming from the rear lately over certain road undulations...think it could be my RC track bar for the reason listed above?
If so, can the bushings be replaced?
