hey everyone, anyone else besides wade done this? wade any results to report?
I defer to the experts on this one. IMHO, it depends on your situation. Mine was starting to rust because the PO had it up north for 15 years. Given that there are stock holes throughout the frame already, I didn't feel a few more would affect the integrity of the frame considering rusting through would be much worse. One thing I did that helped immensely was I bought a boroscope on Amazon to inspect the inside of my frame to assess the damage. Well worth the $40 that I spent (and it's fun to use).Question about the need for drain holes. I'm trying to figure out if this is something that should just be done, or if it depends on how you use your Jeep. If the frame never gets submerged, but just gets whatever might splash from wet/slushy roads, is it still an issue? I have a stock TJ, that so far has not been through any deep water. Frame has no external signs of rust that I can see either.
Thanks.
| 7/8" | 3" | 0.007" | Flexible | 1 | 2 | Galvanized Steel | 27" | Steel | 7353T16 | 6.36 | 5.39 |
| 7/8" | 3" | 0.007" | Flexible | 1 | 2 | Stainless Steel | 27" | Stainless Steel | 7353T26 | 7.33 | 6.29 |
| 7/8" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T514 | 2.67 | 2.29 |
| 7/8" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T817 | 4.30 | 3.69 |
| 1" | 3" | 0.007" | Flexible | 1 | 2 | Galvanized Steel | 27" | Steel | 7353T17 | 6.36 | 5.39 |
| 1" | 3" | 0.007" | Flexible | 1 | 2 | Stainless Steel | 27" | Stainless Steel | 7353T27 | 7.37 | 6.31 |
| 1" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T516 | 2.76 | 2.37 |
| 1" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T819 | 4.53 | 3.89 |
| 1 1/16" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T128 | 3.19 | 2.68 |
| 1 1/16" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T111 | 3.62 | 3.05 |
| 1 1/8" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T129 | 3.24 | 2.73 |
| 1 1/8" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T112 | 3.65 | 3.07 |
| 1 3/16" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T131 | 3.27 | 2.75 |
| 1 3/16" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T113 | 3.68 | 3.09 |
| 1 1/4" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T132 | 3.30 | 2.77 |
| 1 1/4" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 27" | Steel | 7353T18 | 6.58 | 5.57 |
| 1 1/4" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T114 | 3.70 | 3.11 |
| 1 1/4" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 27" | Stainless Steel | 7353T28 | 8.00 | 6.86 |
| 1 5/16" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T133 | 3.32 | 2.80 |
| 1 5/16" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T115 | 3.73 | 3.14 |
| 1 3/8" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T134 | 3.35 | 2.82 |
| 1 3/8" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T116 | 3.76 | 3.16 |
| 1 7/16" | 3" | 0.008" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T135 | 3.38 | 2.84 |
| 1 7/16" | 3" | 0.008" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T117 | 3.78 | 3.18 |
| 1 1/2" | 3" | 0.010" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T136 | 3.43 | 2.89 |
| 1 1/2" | 3" | 0.010" | Flexible | 1 | 2 | Galvanized Steel | 27" | Steel | 7353T19 | 7.24 | 6.20 |
| 1 1/2" | 3" | 0.010" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T118 | 3.84 | 3.23 |
| 1 1/2" | 3" | 0.010" | Flexible | 1 | 2 | Stainless Steel | 27" | Stainless Steel | 7353T29 | 8.23 | 7.06 |
| 1 9/16" | 3" | 0.010" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T137 | 3.46 | 2.91 |
| 1 9/16" | 3" | 0.010" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T119 | 3.86 | 3.25 |
| 1 5/8" | 3" | 0.010" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T138 | 3.49 | 2.93 |
| 1 5/8" | 3" | 0.010" | Flexible | 1 | 2 | Stainless Steel | 10" | Stainless Steel | 7353T121 | 3.92 | 3.30 |
| 1 11/16" | 3" | 0.010" | Flexible | 1 | 2 | Galvanized Steel | 10" | Steel | 7353T139 | 3.54 | 2.98 |
| 1 11/16" | 3" |
This is on my do do list and I have a question, why bother with the degreaser?
The inside of my frame is like the Mojave , dry with lots of sand, nothing greasy or oily. When I drilled the drain holes sand was pouring out like an ancient booby trap in an Indiana Jones movie. Lol
I actually ended up attaching a small piece of chain onto braided steel rope and then put that in my drill and spun the chain around in the frame and it broke up everything into fine dust. Then I just blew it out with my air compressor and grease gun hose and that worked perfect. Got her all coated with Eastwood last month!Maybe, but it is not flexible, so it would be severely limited in what it could do. Also, the two arms look to be way too long to get inside the frame from the side holes. The U shape would need to be only like 2" long on one side to make the turn, and it looks like there is no jet head, so that is additional length that has to make it around the turn. The beauty of the Clog Hog is not that it is a flexible hose, but that it has the jet head that both cleans the frame rail and propels it down the length for you, and it still has a jet that is aimed forward. It is very effective at what it does.
I know that the Clog Hog *does* cost like a hundred bucks, but it did the job perfectly on the first try, and I have used it four times since for frame maintenance on my TJ and several times on my JK, though this is not really a problem for the JK jeeps.
I have also unblocked my drains about five times, too. Better to get something good that will last and have multiple uses then to spend under ten bucks on something that does not look like it would really do much of anything; that's just ten bucks gone, IMHO.
Whatever you do, please share with us the results, and try to include some photos.
Best of luck!
