ARB compressor is installed, but I need an 8-10AWG to 3/8" ring terminal to hook up the ground wire and finish the wiring job. Next up will be planning out the air lines.
Spod is modded and installed, and so is the stock air cleaner. I removed the winch interrupt solenoid. I have to make a bracket to relocate it, and make a cable from the solenoid to the battery.
I attempted to eliminate the mil-spec style battery terminals, but wasn't able to. So, now I'm checking out power distribution block options.
I installed the Hella "yellow" horns, so now my LJ's horn sounds a lot like my Outback. Not sure if that's an improvement or step-backward from the old horn.
