For the rear, the springs are wide enough that an extension from the top won't cause the jounce bumpers to "pluck" the spring coils when extended. It is much easier to add the extension to the top (rear only) as all you need is a longer bolt vs drilling and tapping to lower perch.I planned on adding extensions on the bottom, but why are extensions preferred in the rear? Can I do bottom extensions in the rear as well?
