Savvy body lift (you only want to use solid body lift mounts), Rancho RS5000X shocks, and Currie track bars.
That will set you up nicely for a tummy tuck in the future without having to change anything. With my tummy tuck the JKS rear track bar caused clearance issues. In addition, the OME shocks are much to firm for my liking, whereas the Ranchos ride smooth as butter.
As for the JKS disconnects (or any disconnect for that matter), having owned both disconnects and the
Currie Antirock, I would never personally go back to a disconnect again. The Antirock is my weapon of choice, hands down.
I should add that this is not a bad kit by any means. It's just that I've had all these components at some point or another, and having done things over again countless numbers of times, the only components in the kit I would reuse are the springs (assuming I wanted to stay at 2.5" of suspension lift).
