It sure is purty under there! What’s with the washers on the axle side trackbar bracket? What bracket has enough space for those? My Currie is super tight. I have to bang in the trackbar to line it up.
RJ60 TB bracket. I think they come set up for the larger JJs. I have the smaller JJ on my Currie TB and had to shim it.
I’ve been wanting to re-cover the stock seats, but these https://www.carid.com/caltrend/ covers look amazing. At $144 shipped, they are unbeatable. I went with all black. I was a little reticent and almost went with a black/charcoal, but my rig is black and red, so why break up the color scheme!? The SportTex holds up well to UV, dirt and grime, and they’re breathable.
Reactions: taylormade73
Sometimes I forget some of you guys are in another world!
I've been reading all the threads and feedback on them as well. Look good and sound like they're very durable.
I’m also planning to lift the front a little more. I should be close to 3.5/3.5” plus the 1.25” BL. Maybe I can remove some bumpstop, get down to 1-1.5”. Fiddling now while my PayPal account burns.
I don’t know how they can manufacture them for that price point.
Me either. They seem to fit too well to be universal or applicable for other seats, which would make a little more sense at that price point.
Had to get out and try everything out. I have one small issue I somehow missed when cycling the suspension; rear passenger shock is rubbing the exhaust. Back to the exhaust shop.
The Core 4x4 Rear TB is good to go. Totally clears the gas tank skid and crossmember, but I’ll need to relocate the perches so my jounces line up. One problem with the TB is I cannot get the axle perfectly centered. I’ve got it as short as it can go and I’m still 1/4” off. I need to call Core and make sure they sent me the right TB. They make one for 0-6” lift and another for 6+”.
The rig performed flawlessly. Theraised belly allowed me to crestlots of places I would high center before. Amazing.A couple weeks ago we had a record rainfall in Spokane. It rutted out a lot of the hill climbs. This is good, but the dirt and sand were too loose and I started to fall into this tree. Before I knew it I was in the tree. I don’t have a winch rope now bc it was compromised and I’m waiting on my TRE. So I dug it out3 times, and finally, after calling forum member @Jesse Marquez, who was so gracious to come out to pull me out, I was able to drive out. shout out to Jesse for giving up his time to come help out a fellow Jeeper! He’s got some cool plans for his rig, including an upcoming paint job! My two youngest girls laid bark and limbs in front of the tires to help w traction. Thanks girls, it was all you!
The rig performed flawlessly. Theraised belly allowed me to crestlots of places I would high center before. Amazing.A couple weeks ago we had a record rainfall in Spokane. It rutted out a lot of the hill climbs. This is good, but the dirt and sand were too loose and I started to fall into this tree. Before I knew it I was in the tree. I don’t have a winch rope now bc it was compromised and I’m waiting on my TRE. So I dug it out3 times, and finally, after calling forum member @Jesse Marquez, who was so gracious to come out to pull me out, I was able to drive out. shout out to Jesse for giving up his time to come help out a fellow Jeeper! He’s got some cool plans for his rig, including an upcoming paint job! My two youngest girls laid bark and limbs in front of the tires to help w traction. Thanks girls, it was all you!View attachment 167021View attachment 167022
That's a good Stuck, well done!
Reactions: DrDmoney
Pulled my UA last night, tons of dirt riding on it. May want to drop it periodically for a clean, especially after those pics.
Good to see you getting it out and playing. Glad things worked out and it sounds like all your mods made it better. Let me know when and if you want to come over to move your upper spring pads.
I looked underneath and the skid plate wasn't even touching. 😊 There was a pile of dirt in front of my rear diff though. Didn't stop lockers.
