SOLD 03 Rubicon (Savvy / Currie)
MaloStapalo
Release the Kraken
Веил, колорадо
Price
14,000
Minturn, Colorado
Price: $14,000
Located: 81645 Colorado
Mileage: 103,581
Transmission: NV3550 5 Speed Manual
Walk arounds:
Cold start engine video here:
TLDR: Savvy/Currie 4" aluminum arm johnny joints all around, Currie currectlync, Savvy Alum Oil skid, Savvy Alum Gas skid, Savvy Alum 1.25" body lift, Revolution USA rear Dana 44 axle, Warn Bumper, Rockhard rear bumper, Warn M8000 winch, Tom Woods rear shaft, Savvy TC cable, Currie Antirock, Bestop frameless, 33"x12.5 Goodyear tires, factory air lockers f&r Dana 44's.
I also have receipts for the large purchases such as armor and suspension, roughly $5k worth of parts I had extra insurance on. Everything that I added after the prior owner was purchased new.
Purchased 4/11/18 from private party in Colorado. Jeep will come with any additional fluids that I have such as MTL, Torco, D4, and OEM Dana 44 rear shafts.
Jeep Maintenance and Accessories
(Purchase 4/11/18)​
Fluids
Oil
  • 4/13 10W-30 Valvoline Conventional, new drain plug, & Mopar oil filter – 96,073​
  • 7/22 10W-30 Valvoline High Mileage & Mopar oil filter – 99,348​
  • 10/24 10w- 30 Valvoline High Mileage Syn Blend & Mopar Filter – 101,580​
Transmission
  • 4/17 Redline MTL 75W80 GL-4 - 96,193​
Transfer Case
  • 4/21 Redline D4 ATF – 96,362​
  • Savvy TC shifter cable 10/20​
  • Tom Woods CV drive shaft w/ sealed U joints – 10/30 101,540​
Differential
  • Poison Spyder BombShell Dana 44 Diff cover F&R 5/2 96,630​
  • Torco Racing Gear Oil 85w/140 F&R- 5/2 96,630​
Power Steering
  • Valvoline ATF4 Synthetic – 96,470​
Cooling System
  • Zerex G-05 HOAT Coolant 5/5 - 96,686​
  • Stant 195 Thermostat and FelPro gasket 5/5 - 96,686​
  • Mopar Radiator 5/5 – 96,686​
Suspension
  • Rancho 7000MT RS7239 R & RS7255 F 4/30- 96,589​
  • Currie Johnny Joints with Savvy control arms rear 8/7 – 99,840​
  • MetalCloak rear track bar 8/7 – 99,840​
  • Currie 4” Springs rear 8/7 – 99,840​
  • Currie 4” Springs front 8/13- 99,900​
  • Currie Front Track Bar 8/13 – 99,900​
  • Currie Johnny Joints with Savvy Control arms front 8/13 – 99,900​
  • Currie Antirock front swaybar 8/13 – 99,900​
  • Black Magic JJ washers front lower 9/20​
Air Filter
  • P/O Replaced K&N with stock airbox and new filter 4/11 – 95,700​
  • AC Delco Air Filter A1548C 8/2 – 99,600​
Tires
  • Centramatic Wheel Self Balancer- 6/7/19​
Axle/Steering
  • Currie Currectlync Tie Rod and Drag Link 5/10 – 96,820​
  • Spicer Dana HD U Joint 5-760X 5/10 – 96,820​
  • Spicer Dana Ball Joint Upper/Lower 706944X 5/10 – 96,820​
  • OEM Pitman Arm 5/10 – 96,820​
  • Rancho 7000MT Steering Stabilizer 5/10 – 96,820​
  • Black Magic HD SS bolt track bar axle side 9/20​
  • Revolution Axle RAK44-1 30 Spline USA Dana 44 rear shaft – 10/30 101,570​
Brakes
  • Platinum CarQuest Front Brake Pads 5/11 – 96,830​
  • CarQuest Front Rotors 5/11 – 96,830​
  • Passenger Front Caliper replaced 9/26 – 100,860​
  • Super Blue Dot 4 Racing Brake Fluid (flushed old) 9/26 - 100,860​
  • Raybestos YJ Brake Lines 9/26 – 100,860​
Lighting
  • Hella E-Code H4 Headlight Housing 5/19 – 97,032​
  • ORO LED Taillights 5/19 – 97,032​
  • KC HiLites windshield mounts- 10/28​
  • Rigid Pro D Series Midnight Edition 3” LED Cubes– 11/5 101,793​
Engine
  • Cleaned Throttle Body 5/19 – 97,010​
  • Autolite XP985 Iridium Spark Plug 5/24 - 97,300​
  • Serpentine Belt - 96,400​
  • NTK O2 Sensor Upstream and Downstream – 6/20 98,000​
  • M.O.R.E Bombproof 1” Motor Mount Lift – 4/8/19​
Interior
  • Buchanan Precision 1.5” front seat risers 10/10 – 101,324​
  • Footwell and Soundbar LED replacement bulbs- 6/4/19​
  • Redline Leather Shift Boot-​
Body
  • Shrockworks rock sliders -10/20​
  • Savvy Aluminum 1.25” Body Lift – 3/26​
  • Warn M8000 Winch with Steel cable replaced 6/10/19​
  • Savvy Aluminum oil pan skid​
  • Savvy Aluminum gas tank skid​
  • Warn front bumper​
  • Rockhard 4x4 swing out tire carrier​
  • Currie antirock sway bar​
What it Needs: Local shop report (5/27/20) shows steering stabilizer beginning to leak, drivers rear shock beginning to leak, pitman arm to steering gear joint slightly loose. I do not believe this will be too labor intensive to correct as these are all bolt on replacement parts and the currie tie rod and drag link are super easy to adjust. I unfortunately just ran out of time with my wife and I reevaluating our location and careers.
[/MEDIA]
This is a bangin’ deal! GLWS.
Not sure if you’re up for it, but I’d be interested in buying the E-code housings if you still have the stock sealed beams you could put in
Reactions: MaloStapalo
I was wondering where you had disappeared to. Good luck with the sale and with the rest of life out there. I haven't made it past Georgetown in quite a while.
@MaloStapalo Good luck with everything man. Tough choices to make, but I hope you come out on top of everything. Hope you find a good buyer for the Jeep.
Thank you, I spent a lot of time bonding with the underside of her and the topside of my asphalt parking lot. I will keep it in mind.
Yeah, I had to shift some priorities around sadly. Maybe the time just wasn't right in life for these plans I had for her. Same for me down to Denver. I was furloughed on March 25th and just got a new update that it will be until October 12th at the earliest. I appreciate all your help and teaching me a thing or two ;)
Thank you, I appreciate the kind words. Luckily we are not struggling as bad as some of our neighbors but it has been a new experience here in our valley. As of now, I only have the jeep listed here. I want it to go to someone who will finish out my plans for her, not a craigslist clown.
Thanks man, hope you have been well. Crazy end to our last ski season in the mountains, thats for sure.
I can only imagine. That really, really sucks.
Like you said, at least you're in a better place financially than most who have been furloughed. I hope someone on the forum buys your TJ, as it's a great price, and I'd rather see something like this go to someone who will care for it than some Craigslist kid like you said.
Sad to see. Understandable though during these crazy times. My wife is in ski industry and its been a whirlwind since Feb/March. Good luck with the sale and everything else!
Man, that is such a well set up trail rig. But totally streetable, With thousands in excellent mods. Best of luck, hopefully a good guy takes care of it. That's a beauty.
Price: $14,000
Mileage: 103,581
Walk arounds:
(Purchase 4/11/18)​
Fluids
Oil
Transmission
Transfer Case
Differential
Power Steering
Cooling System
Suspension
Air Filter
Tires
Axle/Steering
Brakes
Lighting
Engine
Interior
Body
Hello, is this Jeep still available ? beautiful build you have
I keep thinking of buying this rig.
I would love for it to stay with someone who would use it and take care of it! If you want to talk some numbers I am open to it ;)
same, the temptation increases each day I’m working through problems on my LJR. My only hope is that I solve them and make mine reliable as hell.
I hope you solve them too, but if not, I can have it delivered to Highlands Ranch!
Updated video: cold start
Reactions: rasband and JMT
