- Price
- 14,000
- Location
- Minturn, Colorado
Price: $14,000
Located: 81645 Colorado
Mileage: 103,581
Transmission: NV3550 5 Speed Manual
Walk arounds:
Cold start engine video here:
TLDR: Savvy/Currie 4" aluminum arm johnny joints all around, Currie currectlync, Savvy Alum Oil skid, Savvy Alum Gas skid, Savvy Alum 1.25" body lift, Revolution USA rear Dana 44 axle, Warn Bumper, Rockhard rear bumper, Warn M8000 winch, Tom Woods rear shaft, Savvy TC cable, Currie Antirock, Bestop frameless, 33"x12.5 Goodyear tires, factory air lockers f&r Dana 44's.
I also have receipts for the large purchases such as armor and suspension, roughly $5k worth of parts I had extra insurance on. Everything that I added after the prior owner was purchased new.
Purchased 4/11/18 from private party in Colorado. Jeep will come with any additional fluids that I have such as MTL, Torco, D4, and OEM Dana 44 rear shafts.
Fluids
Oil
Suspension
Air Filter
What it Needs: Local shop report (5/27/20) shows steering stabilizer beginning to leak, drivers rear shock beginning to leak, pitman arm to steering gear joint slightly loose. I do not believe this will be too labor intensive to correct as these are all bolt on replacement parts and the currie tie rod and drag link are super easy to adjust. I unfortunately just ran out of time with my wife and I reevaluating our location and careers.
[/MEDIA]
Mileage: 103,581
Walk arounds:
Jeep Maintenance and Accessories
(Purchase 4/11/18)
(Purchase 4/11/18)
Fluids
Oil
- 4/13 10W-30 Valvoline Conventional, new drain plug, & Mopar oil filter – 96,073
- 7/22 10W-30 Valvoline High Mileage & Mopar oil filter – 99,348
- 10/24 10w- 30 Valvoline High Mileage Syn Blend & Mopar Filter – 101,580
- 4/17 Redline MTL 75W80 GL-4 - 96,193
- 4/21 Redline D4 ATF – 96,362
- Savvy TC shifter cable 10/20
- Tom Woods CV drive shaft w/ sealed U joints – 10/30 101,540
- Poison Spyder BombShell Dana 44 Diff cover F&R 5/2 96,630
- Torco Racing Gear Oil 85w/140 F&R- 5/2 96,630
- Valvoline ATF4 Synthetic – 96,470
- Zerex G-05 HOAT Coolant 5/5 - 96,686
- Stant 195 Thermostat and FelPro gasket 5/5 - 96,686
- Mopar Radiator 5/5 – 96,686
Suspension
- Rancho 7000MT RS7239 R & RS7255 F 4/30- 96,589
- Currie Johnny Joints with Savvy control arms rear 8/7 – 99,840
- MetalCloak rear track bar 8/7 – 99,840
- Currie 4” Springs rear 8/7 – 99,840
- Currie 4” Springs front 8/13- 99,900
- Currie Front Track Bar 8/13 – 99,900
- Currie Johnny Joints with Savvy Control arms front 8/13 – 99,900
- Currie Antirock front swaybar 8/13 – 99,900
- Black Magic JJ washers front lower 9/20
Air Filter
- P/O Replaced K&N with stock airbox and new filter 4/11 – 95,700
- AC Delco Air Filter A1548C 8/2 – 99,600
- Centramatic Wheel Self Balancer- 6/7/19
- Currie Currectlync Tie Rod and Drag Link 5/10 – 96,820
- Spicer Dana HD U Joint 5-760X 5/10 – 96,820
- Spicer Dana Ball Joint Upper/Lower 706944X 5/10 – 96,820
- OEM Pitman Arm 5/10 – 96,820
- Rancho 7000MT Steering Stabilizer 5/10 – 96,820
- Black Magic HD SS bolt track bar axle side 9/20
- Revolution Axle RAK44-1 30 Spline USA Dana 44 rear shaft – 10/30 101,570
- Platinum CarQuest Front Brake Pads 5/11 – 96,830
- CarQuest Front Rotors 5/11 – 96,830
- Passenger Front Caliper replaced 9/26 – 100,860
- Super Blue Dot 4 Racing Brake Fluid (flushed old) 9/26 - 100,860
- Raybestos YJ Brake Lines 9/26 – 100,860
- Hella E-Code H4 Headlight Housing 5/19 – 97,032
- ORO LED Taillights 5/19 – 97,032
- KC HiLites windshield mounts- 10/28
- Rigid Pro D Series Midnight Edition 3” LED Cubes– 11/5 101,793
- Cleaned Throttle Body 5/19 – 97,010
- Autolite XP985 Iridium Spark Plug 5/24 - 97,300
- Serpentine Belt - 96,400
- NTK O2 Sensor Upstream and Downstream – 6/20 98,000
- M.O.R.E Bombproof 1” Motor Mount Lift – 4/8/19
- Buchanan Precision 1.5” front seat risers 10/10 – 101,324
- Footwell and Soundbar LED replacement bulbs- 6/4/19
- Redline Leather Shift Boot-
- Shrockworks rock sliders -10/20
- Savvy Aluminum 1.25” Body Lift – 3/26
- Warn M8000 Winch with Steel cable replaced 6/10/19
- Savvy Aluminum oil pan skid
- Savvy Aluminum gas tank skid
- Warn front bumper
- Rockhard 4x4 swing out tire carrier
- Currie antirock sway bar
