You're mixing SAE and Whitworth, that's what you know.I can't even remember the thread size and pitch of our lugs.
Generally a 1/2" bolt uses a 1/2" nut but what the hell do I know?
Does either rod end fit the arms?When you've messed with something as much as those guys have (Blaine too), I suppose it becomes second nature.
I maintain a 1964 Mini Cooper, the mention of anything British is mildly painful.You're mixing SAE and Whitworth, that's what you know.
So you are well familiar with the Prince of Darkness?I maintain a 1964 Mini Cooper, the mention of anything British is mildly painful.
Nope but I'll check it out. More The Italian Job for me, the first one.So you are well familiar with the Prince of Darkness?
Lucas is often referred to as the POD due to the fubar electrical on British cars.Nope but I'll check it out. More The Italian Job for me, the first one.
Did you drill the hole out to 1/2" and if so, did the rod end studs fit?Yep, they fit the arms perfectly.
If you buy one of these, we'll won't get to snicker quite so much when you post silly questions.I haven’t drilled them yet, but I’m going to tonight.
https://www.amazon.com/dp/B009I1KLY2/?tag=wranglerorg-20
There is no manufactured difference in those hole diameters as far back as 90.I think I was more-or-less curious if there was a difference at all in the axle housings on the TJs, being as though my sway bar mounting bolt holes are seemingly smaller than others.
But yes, I'll buy one of those. That would actually be helpful to have around!
No, and no, but maybe, yes.Have we determined that RJ really is having us drill the sway bar mounts now and didn't just send the wrong parts?
This touches on one of my pet peeves... People calling out bolt sizes by wrench size. It drives me crazy! It's not a 3/4 bolt... It's a half inch bolt that uses a 3/4 wrench (or socket). I see it ALL THE TIME. It's annoying...I can't even remember the thread size and pitch of our lugs.
