What size tires will fit a stock Wrangler TJ?
I like that..If Im not doing any serious off roading - just beach really - then am I ok with 33s and a 2.5 inch lift on a Wrangler, in your opinion.
You'll likely be fine but the ride will feel harsh due to the limited shock uptravel. IMO, it's not worth compromising ride comfort for the "33" look". For 33s you really need more lift than 2.5". You can consider adding a 1.25" body lift (Savvy Offroad sells a great one) to the 2.5" suspension lift and then choose the right shocks so that you don't compromise ride quality. If you go this route, you'll also likely need adjustable control arms and SYE and/or new DC driveshaft in the rear. 33s are a lot of work, really. I recommend to stick with 31/32s for 2.5" lift and keep it simple and enjoy your Jeep.
This thread is to serve as the be-all end-all answer to questions such as "What is the largest size tire I can fit on my stock Wrangler TJ?".
The answer is simple: You can put a 31x10.50 - 15 tire on your stock Wrangler TJ with stock wheels. It may rub a little at full lock which is easily corrected with a couple of washers on the steering stops. A 31" tire will still perform just fine off road and won't encounter any major issues with rubbing under full tuck.
If all you're after is looks and not functionality, you can often times fit a 32" or 33" tire on your stock TJ, but at that size you will more than likely do some serious damage if you take it off road. Anything larger than a 31" tire needs a lift (among other things) if you want to have a proper, functional setup.
NOTE: Depending on your engine, transmission and gear ratios you may suffer disappointment in your performance after installation of larger tires.
I'm thinking about putting the 31x10.5 on mine, which is totally stock. I have a 4.0, manual, 3.73 ratio and my stock wheels are 15x7, I need to know if I will suffer disappointment lol
Probably not. A six will push 31's just fine almost no matter what gear ratio you have. Just don't disconnect. It'll probably rub the spring perches in front when you flex.
I'm running 31x 10.5 x 15 on mine no issues at all...as long as you have stock fenders...(pocket fenders will reduce that gap and it will rub when flexing) So basically don't do what I did haha
I have stock fenders and it's a 5-spd manual since mine's a 98.
Reactions: Kiwi TJ
Hey @psrivats , replacing my wheels with your exact set-up. Do you have a side shot of your rig somewhere I can have a look-see?
This is the best I have. But note that it's parked on a bit of a slope.
I'll say though, don't go by looks, set the rig up so that you have the proper clearances for the tire size you choose.
Reactions: TJRick and pchphx
Grateful for this thread. I have a question about the OP's note:
I have a 97 SE (2.5L). I'm currently running 30x9.5s on steel 15x7s or 15x8s (need to check). If I go up to 31x10.5s would I have any issues with my engine, transmission, or gear ratios, as hinted in the "Note" above?
Do you know what gear ratio you currently have?
Thanks Chris. Yep, as you typed, I was finding that same link in a 'sticky' post you wrote. But looks like that listing only goes back to '98, and of course mine is a '97. But I followed the advice on your other sticky, and I just checked the tag on the rear differential. I've been the only owner since '98, and I seriously doubt that the first owner would have changed it (the Jeep was as bare-bones "SE" as they come). My tag says: 4__11__5957__5.
So, 4.11? And based on your post here, I should have a AX-5 transmission. And from your other post here (these are all so helpful, thanks), it sounds like I should have the standard, stock gear ratio of 4.10—even though mine says 4.11?
Yep, 4.11 which is what it should be 👍
I didn’t realize that build sheet tool only went back to 98.
As you know, owners of new Jeeps like to replace their tires and wheels the first chance they get. I'm in the market for what they are taking off! Does anyone know if 17" rims with 245/75R17 Goodyears would fit on my bone-stock 2004? There are five 2019 wheels, just waiting for me to pick them up. I did a comparison on TireSize.com and its just a wee 1/4" in radius, and almost an inch of width less. The second image is the set that I am interested in.
Edit: The required spacers, https://www.amazon.com/dp/B07T896NRW/?tag=wranglerorg-20
They might. If you have proper backspacing on the wheels you should be fine with the turn radius. To know for sure you’d have to cycle the suspension. By that point you’d already own the tire/wheel combo and you’d find a way to make it work.
Thanks! I’ll probably just go for it. Three hundred for five new wheels and tires is something I can’t resist.
  • Wow
Reactions: Captainchad
Yeah, and in the end, you could always add a 0.5” spacer or body lift if you needed to.
