I hope when people saw your Jeep with that grille they were using the proper "vehicle neutral" pronouns to refer to it
A couple observations from that day. The Jeep's turn signals stopped working. And BMWs don't wave back.
Yep, and the cost to replace the lit up warning light panel is more than the vehicle is worth and the new one will also die a horrible death in short order.Your dashboard should have been lit up like a Christmas tree as well with warning lights.
Imagine if I had found a Ferrari grill instead!Yep, and the cost to replace the lit up warning light panel is more than the vehicle is worth and the new one will also die a horrible death in short order.
The down leg out of bent angle is only as strong as the smallest cross section. That is the section circled in blue. The bolts into the dash that are supposed to make everything stronger are only 6 mm or 1/4". The flange they are bolted into is 18 gauge sheet metal. You can literally grab ahold of it and flex it back and forth with your fingers when the dash is out. It is unsupported from the bottom of the windshield to about the middle of the door opening. It is not strong or a substantial strengthening area to bolt a cage to. It was only designed to provide a bit of stiffening to the door opening for the hinges and to hold up the dash.What is the advantage to doing it this way as oppose to the way the Poly cage mounts?
If bent angle were strong enough to be anything resembling a cage, then why not make the B and C pillars out of it along with all the connectors over your head?
Those bent angle legs started before there were cage kits when there was only those or a custom cage. Then that jerk in AZ came up with that bullshit bent angle and everyone copied it. Several companies used to offer the through the dash stuff but no one buys it due to pulling the dash which they don't want to do.I get this.
And the only reason so many companies went with this design is because it was easier to install, is that correct?
If that is the case, what I mentioned a few posts back is true. They made it easier to install in favor of fucking you over in the long term when you have to remove the dash.
The more I look at that design, the more stupid it seems. The idea that those tiny boles and 18 gauge sheet metal are going to stand up to multiple rolls down a steep incline seems silly.
I still can't get past the capturing of the dash though.
Just for the record, I was never even considering those cages with the legs we are talking about. This isn’t something I just wanted to knock out really quick, I’ve been doing the research, so thank you for all the information you provided as well.Chris, if you really want to upgrade the factory roll bar. I would find someone who does NASA/SCCA legal cages for actual race cars in your area. I have a good friend who did this for a living for many years and still does a lot each year. His cages combined with the other required safety equipment pass all inspection and have saved many life’s on the racetrack including my wife’s. I learned tube bending and construction from him, and if you where in the area I would be happy to help. Well technically me and Alex would because the bender is at his house strategically to make sure all projects end up there. ;-)
If you want to understand cages better a quick read brought the NASA rule book would help. The roll bar in your Jeep would be slightly different but you would want to incorporate as many of the rules/features as possible.
Starts on page 44.
https://nasa-assets.s3.amazonaws.com/document/document/282/2020.3.pdf
One thing to note about those fake flat cages people run. They would not be allowed, for track days you either have to stay stock, or have a signed off certified cage. To actual race you must have a signed off cage. Those things are neither fish or fowl and would imagine they are likely to be more dangerous.
I am confused how the discussion about the front legs keeps coming up as an option at all. No racing organization anywhere would allow that.
In SCCA/NASA you could do time trail style racing with just a certified/legal roll bar only and they would sign off on it. If you added this crappy front plate down leg things you would not be allowed on track. Said another way, they would view your car as safer if those sections didn’t even exist.
Pull the dash put. Put the appropriate size tubing down behind it, to the appropriate size plate on the tub. Or don’t do it at all.
Do you know the difference between a BMW and a Porcupine?A couple observations from that day. The Jeep's turn signals stopped working. And BMWs don't wave back.![]()
I think I know, but I'll play along.Do you know the difference between a BMW and a Porcupine?
This is usually always true.My guess is the BMW the prick is on the inside or something like that.
Doesn’t Jerry drive a BMW? Or is that his wife’s?Even in Germany they feel that way about BMW drivers.
