Doctor Bone Smash
I’ve been looking at some Cherokee rims in 16x7. Liberty rims would do the trick also.Do you know of a good aluminum rim choice? Adapters required?
Is this something you found or put together yourself. Seems like its WAY overkill for the type of terrain that 31's will let you get into. I mean, sure, thats the name, but 10k+ in axles, just to run 31's? Seems like that's just spending money to spend money. A lot of the build is good stuff though, for ANY build.Ive had this built in my notes on my phone for a while now. A Rubicon killer
Project “Overkill”
- 1” H&R Springs or Custom Eibach Springs with the longest Free Length and Dialed in Spring Rate
- Artec Rear Coil Correction Kit
- Rear Shock Outboard Mod
- Artec Front Coil Buckets w/Air Bumps
- King Air Bumps Front & Rear
- 1.25” Savvy Body Lift
- Savvy Belly up Skid
- Rubicon 4:1 Trans Case Swap
- Savvy Gas Tank Skid
- Dynatrac ProRock 44’s (Ground Clearance)
- Front & Rear ARB’s
- Powertank for Airing Up & Down
- Falken WildPeak M/T’s
- Alcoa Forged Alum Factory 15” TJ Wheels w/OMF Beadlock Added
- Black Magic Brakes Hydro Boost
- Currie Rear Track Bar
- JKS Front Track Bar
- Savvy Upper & Lower Control Arms
- Currie Anti-Rock
- Savvy Front Bumper
- Warn XD9i w/ Synthetic Rope
- PSC BFH 2 Rear Minimalist Bumper
- Savvy Sliders
- Modified Cage
- Recaro Expert M Seats
- Bestop Soft Half Doors w/ Alum Paint Matched Skins to Replace the Fabric
Re: moving mounts, is the goal to gain articulation/travel, and therefore maintain more tire contact (avoid tires in the air)? Avoid scraping the rears?What about moving shock mounts on this 31" build? What 2" springs give the most free length?
| Spring | Free Length (inches) | Rate (lbf / in) |
| BDS 034204 | 18.50 | 158 |
| BDS 034206 | 13.75 | 200 |
| OME 2932 | 18.89 (A), 18.50 (B) | 140 |
| OME 2933 | 19.48 (A), 19.09 (B) | 140 |
| OME 2941 | 15.35 (A), 14.76 (B) | 140 |
| OME 2942 | 14.96 (A), 14.37 (B) | 160 |
| OME 2949 | 14.56 (A), 13.97 (B) | 216 |
| Pro Comp 55297 | 17.87 | 170 |
| Pro Comp 55298 | 13.54 | 175 |
Not necessarily. However, tire choices are limited and I view 32" tires like 37s. It's a weird size where if you build for them you might as well just get the next size up tire. In the case of 32, just go with a 33. For 37, just go with 40. In either case, it's the slippery slope!Are 32's absolutely out of the discussion? I always considered 32's and under kinda of the tipping point for having to start spending a lot more money on parts.
Couldn't agree more. I guided a friends daughter, who was driving a TJ with a TT and 31" tires, through some tough trails. She tested the skids, but went almost everywhere the rest of us on 33s and 35s went.Overall it is the same concept, except less focused on lifting the Jeep to make clearance.
Fun part is when you are over geared for the 31s. I am on 31.7" and geared 4.56, this thing just goes.
Beefing up components, and adding more armor should be just as important if not more.
Reason i say this, most trails i have been to, are all rotted out with bigger tires. Sometimes brute forcing a way through is the only option, otherwise id be spinning wheels in the air while hung up on the pumpkin. Same concept with rocky areas, but i take my sweet time around rocks. And if it looks like i have no business of being/going there, i don't.
But, overall having limitations makes you a better driver, unless you are dumb by nature.
I have been on two local group runs, and can clearly tell who is using their brain to overcome an obstacle. I assure you, they are typically not the guys who run 35-37s.
Keeping it light, but building it to take abuse is the intent. I already have a Savvy UA and Savvy gas tank skid for the underside. The rear will be a Rubicon 44, with a Detroit Truetrac 30 up front. I know this isn't a locker, but it's parts I have around now. There's a 44 front in the garage as well, which will be reserved for future use, if needed. I did consider the Currie steering, that's what I have on the LJ, but I also have all the new parts needed for the ZJ upgrade, so that will be going on first. I do have a set of Genright body mounts, courtesy of @Chris, but I'm going to start out with a Savvy BL.I had a lot of fun for years on 31s. But also a lot of frustration.
My advice is to focus on lifting everything you can because you're going to need everything you can get (belly, bumpers, body mounts, linkages, etc). Also keep it as light as possible so that when you do get hung up you can hopefully push your way over it. While ZJ steering upgrade is plenty for the street and light trails, upgrading to the Currie steering may be worth looking into since you're going to be bashing it a lot.
You've seen my stuff and I'm not messing around with this one. It will get double adjustable aluminum control arms. Also, I have both a 231 on the shelf, with a JB Conversions SYE, and a 241OR. I just haven't made up my mind which it will be. Since my theme for this is light and nimble, I'm leaning in the direction of the 231. The track bars will also be replaced.My thought process was 2" suspension lift and 1" body lift would be fine for up to 32's, and that small amount of lift negates the need for a SYE, control arms, track bars, etc. Also, depending on stock gearing and/or stroker motor, you can get away with factory gearing for longer.
It’s just something I put together once while I was bored.Is this something you found or put together yourself.
It’s overkill for sure, hence the, “Project Overkill,” name in my post as you mentioned.Seems like its WAY overkill for the type of terrain that 31's will let you get into.
You have a good point and then again some people have more money to spend than others. More ground clearance than a Dana 30, high pinion, bigger and thicker tubes, available with bigger brakes, spindles and lockable hubs, custom width to offset the forged factory Jeep wheels backspacing, etc.but 10k+ in axles, just to run 31's?
It's not out of the question. The problem I'm having is finding a progressive spring in the 2.5" and under range. Ideally, I'm looking for a progressive spring with a lighter spring rate and longer free length. If I can't find a spring that flexes with a lower lift, moving shock mounts won't necessarily add any value.What about moving shock mounts on this 31" build? What 2" springs give the most free length?
I think I should have named my project "Overkill". Like some of the things on this list, I'm working to build that "sleeper"!Ive had this built in my notes on my phone for a while now. A Rubicon killer
Project “Overkill”
- Currie Anti-Rock
- Savvy Sliders
- Modified Cage
I initially looked at the Currie setup for a 1" spring lift. Here's what the notes page says:Can anyone verify that the Currie steering will work with a low lift such as a 1" or 2" lift? I've read issues with the length of the tie rod, or clearance issues with low lifts.
Can't think of a progressive rate spring other than factory. JKS makes a dual rate spring in 2", but not sure what value would be gained with the light rate once the weight of the jeep in on it.
First 5 years of wheeling was on OME 2" springs and 31's. I wheeled harder on that setup than I ever have to date.
Yeah, losing an inch of up travel from the stock 4" would not be beneficial IMO.I initially looked at the Currie setup for a 1" spring lift. Here's what the notes page says:
"NOTE: This unit is designed to be used on vehicles with 4" of lift. It can be used on vehicles with less lift, but the vehicle must have a minimum of a 2" bump stop (over stock). Also, on vehicles with no lift, 2 of the tie rod ends may need be trimmed to achieve proper adjustment."
The bump stop steered, pardon the pun, me away.
