What bumper your LJ has?I can't wait to raise my rear bumper - after that the consideration of stretches + axle + tire size start to open. I hope to never get to those.
Fuel Cell like a fuel cell in the cab rear?Depending on how you stretch dicking around with the rear bumper may not be worth the hassle unless you go fuel cell.
yes vs a genright stretch tank under the tub.Fuel Cell like a fuel cell in the cab rear?
NextVenture plateWhat bumper your LJ has?
The brackets don't do anything that is inherently wrong, as best as I can tell. What is wrong are many of the claims surrounding them leading to false expectations and poor understandings of how things work. The financial cost is low, but the effort to install these things is not low. You've seen the lengths I've gone to on mine for little improvements. I'm not afraid to put myself through a miserable hell to get some small incremental gain that I might not even realistically benefit from. Nor do I glorify these things as being something they aren't. That's where I am on mine. Knowing what I know (about shocks in particular) and in a world where I start over, these brackets are not for me because the payoff for the effort is not there.No my only question, from the beginning, has been what do these do that is wrong.
If this was your comment many pages ago I think many could see why you may not be in favor of them. The roll center would be a plus, but the AS would be a bigger plus. Let folks decide what products to use. We have 600 plus comments before you stated that for a bit more work there is a better option. A lot more money too.It was because the examples given were mixed between TJs and LJs.
The answer you are looking for is that for a similar amount of work (and more money obviously) I can get the Savvy stuff in there. And because I'm a believer in the power of shocks, I would be doing that anyway. So whatever improvement the geo kit gives from the higher roll center becomes a moot point for me.
are we gonna be seeing a new BFH series in the future?I can't wait to raise my rear bumper - after that the consideration of stretches + axle + tire size start to open. I hope to never get to those.
Are your an LJ?yes vs a genright stretch tank under the tub.
Alright I just went out and did my best possible job at inputting my geo correction numbers into the Triaged calculator. The other calculator wasn’t meant for this kind of setup. I’m not going to be able to calculate a stock setup because there are too many variables in this calculator. I used the top of my bell housing for CoG.
Here it is as it sits. 117% AS. The lower the weight of the Jeep, the less AS it has. I have no idea how much mine weighs but I would say 4K is a decent average. The lower the CG I input the higher the AS goes. That’s another factor to think about.
View attachment 251657Here is what the AS would be with 5/8” lower holes in the upper towers. 104%. When I did a 3rd hole down it went to 84%.
This calculator only tells me roughly what happens when I change things. We know it hops, so the numbers don’t mean shit until I run it and it doesn’t hop. I’ll be a guinea pig for yall and do some testing with video and post it up. I’ve got a good local climb in mind.
It will probably continue to hop until you can get it to not unload so quickly when the axle loads up and breaks traction. SHOCKS!!!Here it is as it sits. 117% AS. The lower the weight of the Jeep, the less AS it has. I have no idea how much mine weighs but I would say 4K is a decent average. The lower the CG I input the higher the AS goes. That’s another factor to think about.
Wouldn't that be 2022 TJ Non-Limited Fest? Or No Unlimited Fest?2022 Has been renamed to "TJ Limited Fest", since clearly that's what they are.![]()
I agree that shock rebound will make a difference in the overall result but I should still be able to make relative differences by changing the geometryAlright I just went out and did my best possible job at inputting my geo correction numbers into the Triaged calculator. The other calculator wasn’t meant for this kind of setup. I’m not going to be able to calculate a stock setup because there are too many variables in this calculator. I used the top of my bell housing for CoG.
I sincerely hope not, at least not one that will be this. I want to have fun on it for a few seasons before making that drastic of a change. I'd bet either a V8 or R2.8 would be under the hood before anything else big like that.are we gonna be seeing a new BFH series in the future?
lots of info in there and fun to interpret even give some info on pinion angles and rear steer IIRC.Alright I just went out and did my best possible job at inputting my geo correction numbers into the Triaged calculator. The other calculator wasn’t meant for this kind of setup. I’m not going to be able to calculate a stock setup because there are too many variables in this calculator. I used the top of my bell housing for CoG.
Only to a point. These hops are slower speed movements. If one were to try and tune out the hops, the rest of the ride would be awful.I agree that shock rebound will make a difference in the overall result but I should still be able to make relative differences by changing the geometry
