So, are you going to run without a front drive shaft until you sort out the front?
Absolutely yes haha.So, are you going to run without a front drive shaft until you sort out the front?
I will be selling both the Dana 35 and Dana 30 to recoup some cost. The Dana 35 will be complete with brakes, the Dana 30 will be stripped some at this rate depending on what I can keep or reuse from the HP30 purchase. Definitely ok with adding to the challenge, I like to physically see progress with mods haha. Just wanting enough recouped from selling those two axles to be able to buy another exhaust manifold/header & fix that ticking noise.Also, are you going to sell your LP30 to recoop some cost? Just wondering if it would be worth the effort to buy an open carrier for 3.73's, swap in a ring/pinion, a new pinion seal, and have someone set it up, hoping your carrier and pinion bearing are in good shape so you aren't paying for an install kit, then that way your LP30 would be more attractive to sell, and would buy you some time. I've been wheeling for years with a LSD rear and open front. Adds to the challenge! Just thinking out loud here.
Lol my stereo was stolen!!ticking noise? just turn the stereo up, lol!
Several inches with the benefit of a less severe driveshaft angle.So, honestly, my buddy has a 99 with 33 x 12.5 tires, ax-15, and 3.73 gears. He's around 210,000 on the original engine. It's not terrible to drive. Sure you downshift a bit, but it is livable.
On the other hand, how much clearance does the HP Dana 30 get you?
I appreciate that! I have the same one and will be considering that location now lol.Glad you are happy with 1Factory Radio. They did mine, and it works great, no regrets. On the XM radio, I have the Onyx, and mounted it on the drivers side dash top, between the pillar post and the instruments. Gave up on the window cup mounts, and bought a short adjustable with a circular base, that sticks right to the dash-top. I've seen a lot of cb's mounted there, so not sure if this helps or not.
Ray
Thats a great mounting location! I got my satellite radio used so mine didn't come with a mount like that, just the vent mount. I did manage to find a location for it today though! Right above my newly mounted CBHere are a few pics. I bought the mount from either Satellite Super Store, or the Sirius site. Have one in my truck also, holds up great, even in triple digit heat.
Ray
View attachment 21990 View attachment 21989
Thats a great mounting location! I got my satellite radio used so mine didn't come with a mount like that, just the vent mount. I did manage to find a location for it today though! Right above my newly mounted CB.
Yessir it sure was hard finding a tow package xj lol. With it having 3.73s my tj's Dana 30 axle shafts should swap right over correct? I know the 3.73's have a different carrier. Hoping I don't need to buy new axle shafts right off the bat.Sweet!
Fingers crossed.I want to say yes, but I haven't researched it enough to know for sure. Maybe shoot that question to one of the gear vendors or Allen@AOR and they can confirm.
