I had a steering part printed when I restored my brothers old RC Jeep
It's held up great but I haven't printed anything for my Jeep.
That would be really handy to have before a trip through the car wash
Indeed, makes it real slick to take on and off that long CB antenna.That would be really handy to have before a trip through the car wash
I use Hubs and Xometry quite a bit. Their instant quotes are usually reasonable(for small parts) considering the price of a printer than can sinter metal. They can do pretty much anything else as well such as CNC.I'd give a kidney for a good metal 3D printer.
I'd have to give another kidney for the engineering knowledge and programming skill to use it properly.
You can get an Autocad Fusion 360 license for $330/yr or a Solidworks for around $5500 plus a yearly update fee. They are cheap compared to a dressed up seat in Mastercam that will run 30k plus the yearly update charge. Most of the software now has a relatively low cost to get a basic copy, but if you actually want to use it you have to buy multiple add-ons that are usually more expensive than the base software.I use Hubs and Xometry quite a bit. Their instant quotes are usually reasonable(for small parts) considering the price of a printer than can sinter metal. They can do pretty much anything else as well such as CNC.
I'd imagine software licenses for SolidWorks, Solidedge, and AutoCad are quite pricey; my employer covers the costs on these but I think they offer limited time trial versions for free.
if you have a newer ipad pro or something, there is inexpensive/free software you can use to 3d scan things via the ipad pro.Do you guys know of 3D scanners to compliment the printers you are using? I have been trying to make an exact copy of a simple plastic part forever and no dice so far.
That pump module is impressive.I have a few printed parts on the Jeep, but I mostly use the printer to prototype. I typically print in PETG and have had relatively good luck with the parts holding up. I think right now I have a couple of brackets on my fuse box under the hood that have been there for 6 months or so and haven't deformed yet. I also have a shift knob, switch plate brackets, speaker grills, sensor mounts, pull handle for the tumble seat, cell phone mount as well as others I'm sure I have forgotten. I have prototypes for the shifter I made for the 3550, fuel pump hanger, overhead switch panel, cb mount bar, defrost grille, throttle body, also many brackets. I can print them out cheap, check fitment and such, then decide whether to make a part or not. That has been the most useful for me.
I've also printed prototype parts for vehicles. I was able to be part of a team that printed a prototype supercharger mock-up for the first 2014 C7 Stingray for Magnuson. Just to check design fit and clearances.I have a few printed parts on the Jeep, but I mostly use the printer to prototype. I typically print in PETG and have had relatively good luck with the parts holding up. I think right now I have a couple of brackets on my fuse box under the hood that have been there for 6 months or so and haven't deformed yet. I also have a shift knob, switch plate brackets, speaker grills, sensor mounts, pull handle for the tumble seat, cell phone mount as well as others I'm sure I have forgotten. I have prototypes for the shifter I made for the 3550, fuel pump hanger, overhead switch panel, cb mount bar, defrost grille, throttle body, also many brackets. I can print them out cheap, check fitment and such, then decide whether to make a part or not. That has been the most useful for me.
I have printed both and ABS is a pain. It has a burnt plastic smell when printing. ABS also seems to want to warp and detach from the print bed easier than PETG. The difference in durability is negligible for my uses. I prototype everything in PLA as the print times are faster and the failure rate is much lower. I have some really cheap Amazon filament as well as some high quality stuff, I can't really tell much of a difference.I've heard that PETG is actually easier to print than ABS. I found some cheapie PETG off amazon not terribly difficult. I'm using a really basic low-end machine but with cura software it's proven to do a nice job with some tweaks (ender 3 pro).
The real tech is in the electrical harness.That pump module is impressive.
What sort of plastic did you use for that? It'll be interesting to see how it holds upI printed some axle tube guards today. They are not sealed and I know they won't keep everything out, but not unlike the factory plastic ones they will keep the big stuff out.
