It’s not as bad as it looks. It’s really just cutting and flipping the crossmember’s end pieces side for side (and flipped). Then get the skid into position and weld tabs to the frame that line up with the newly flipped ends. I’ll eventually redo mine because I think it’s worth gusseting them too.I have a set of Genright body mount brackets for the TJ. The only reason they haven't been installed is because of the Savvy MUA. With all the stuff on my to-do list, removing the cross-member and fabricating a mount isn't at the top of my list.![]()
This is on my must do list, along with a tie rod flip, so I'll get to it over the winter!It’s not as bad as it looks. It’s really just cutting and flipping the crossmember’s end pieces side for side (and flipped). Then get the skid into position and weld tabs to the frame that line up with the newly flipped ends. I’ll eventually redo mine because I think it’s worth gusseting them too.
When I did my front refresh I did the whole kit (rotors, pads, calipers). But I think unless you have any issues with your calipers it’s not necessary (and makes it easier). Especially for the rears that only see 30-40% of the force.Should I get Centric rotors for my rear disc brakes when I replace my brake pads with BMB Pads?
I wouldShould I get Centric rotors for my rear disc brakes when I replace my brake pads with BMB Pads?
If any jeep here deserves raised mounts it's yours.Can you come over and do all of mine pleaseView attachment 286584
Lol, I read that wrong. Yes, I’d do pads + rotors always - calipers only if you’re finding issues or sticking in what you have now since they’re OEM replacements effectively.When I did my front refresh I did the whole kit (rotors, pads, calipers). But I think unless you have any issues with your calipers it’s not necessary (and makes it easier). Especially for the rears that only see 30-40% of the force.
I told him that recently, he just complained that the genright prices went up… so now he’ll complain until the next increase before buyingIf any jeep here deserves raised mounts it's yours.
Hmmm you guys have made some compelling arguments here. I think you’ve talked me into it.I told him that recently, he just complained that the genright prices went up… so now he’ll complain until the next increase before buying![]()
I’m partial to the genrights
Interesting, the tnt ones look like they tuck up higher than the genrights. I’ve never seen them before
Compare the shape, they don’t look to be higher to me with a straight line vs curved.Interesting, the tnt ones look like they tuck up higher than the genrights. I’ve never seen them before
