They’re great tires.How’d you like the duratracs?
They are great if you like loud expensive tires with weak sidewalls.They’re great tires.
What’s your go to A/T tire @mrblaine?They are great if you like loud expensive tires with weak sidewalls.
Love the vents! What temp is it running at after you installed them?Well here are the vents installed. I didn’t complete the venting holes because the hole saw was making quite a racket and my neighbors can only tolerate so much before they report me to the HOA. I’ll finish making them functional another day at a different location. Also I’ll get some better pics but overall the look of them is extremely underwhelming, just as I hoped.View attachment 266345View attachment 266346
No idea lolLove the vents! What temp is it running at after you installed them?
Since you are in Monroe, is your shop Hamm's?My 4X4 shop recommended the conversion, and when the called the parts distributor they knew exactly what the technician was talking about and had the parts to us the next day.
They are only loud if you are young and still have most of your hearing. I’m in my 40s, and I can go either way with the loudness.They are great if you like loud expensive tires with weak sidewalls.
Yes, Adham Sproat run’s it. I am originally from Monroe (just returned after being gone for a long time for work) and it is cool that I have a great shop right here. He put on my 4” long arm lift, trussed both axles and my ball joints, as well as many other things.Since you are in Monroe, is your shop Hamm's?
Engine temp won't change in any way noticable. But the intake temp might decrease about 5 degrees and the under hood temps should also decrease some.Love the vents! What temp is it running at after you installed them?
He trussed your ball joints?Yes, Adham Sproat run’s it. I am originally from Monroe (just returned after being gone for a long time for work) and it is cool that I have a great shop right here. He put on my 4” long arm lift, trussed both axles and my ball joints, as well as many other things.
I have driven by that place a million times, but you are the first review I have read.Yes, Adham Sproat run’s it. I am originally from Monroe (just returned after being gone for a long time for work) and it is cool that I have a great shop right here. He put on my 4” long arm lift, trussed both axles and my ball joints, as well as many other things.
They're tiny, but very strong.He trussed your ball joints?
