05 exhaust diameter questions
since the dawn of time, man has pursued how to go faster, even with a tractor motor....😁
I wish I had some dyno data to back it up, but I really did feel a low end loss of power when I went from stock system to a Magnaflow full 2.5" system from exhaust manifold back (including new cat) in my '97 4.0.
Edit: I noted similar butt dyno INCREASE in low end power when I went from a JBA header (3-2-1) to a Banks header (6-1) with my 4.6 stroker. That one I do plan to get some dyno data on.
I think most folks would be hard pressed to "feel" the difference. I used to spray a 35 shot on a bracket car years back. You could barely feel the difference when the nitrous hit. 10 or 20hp would probably be invisible to most butt dynos.
2.5 " Why start out limiting potential ? If you had a V-10 , ( 488 c.i.d.) Dodge pickup would you put 2.25 dual exhaust on it ?
However , if you believe that you "NEED BACKPRESSURE " to run right why not go with a 1" system for that locomotive type torque. :rolleyes:
I've got dual 3" front to back on my 505 cubic inch Dodge pickup.
But the TJ has a 2.25" on it lol. To be honest I don't know how I ended up at 2.25" though, that exhaust has gone through so many iterations it's probably just what I had laying around
Reactions: ColoJeep
Yep. Butt dyno may be mostly placebo (you feel what you expect to). Interestingly, I was talking to a tuner today who said he has repeatedly seen increase in torque from 1500 RPM on up with open headers vs any exhaust šŸ¤·ā€ā™‚ļø
And there are those who swear open headers make less power than full tunes exhaust …
Reactions: Woodrow
Another datapoint the 4.9L straight 6 Ford tractor motor typically sees 3ā€ exhaust piping as a ā€œperformanceā€ upgrade. And they ā€œfeelā€ lazier than our motors … I’d say a 4.0 feels peppy compared to a 4.9 Ford … but Ford folks swear by them
I was thinking they also did one comparing exhaust tubing sizes; and IIRC, it didn't matter much.
Season 5 episode 16 was The one I was thinking of but The 2.5 vs 3ā€œ I found on YouTube. Higher rpm’s max HP is going to like bigger pipe- of course they are running higher HP stuff but engine Dyno is picking up at 3000 rpm up so leaves room for some speculation what is happening below…
