If the switch arm is metal and all the pieces are there, can it be brazed back together?
šŸ™ At the time I could only see the part that was broken behind other steering components, so I started researching, and when I finally found it I got it on order ASAP so I can get this Jeep back to this kid. Itā€™s in really rough shap. I canā€™t braze, but I believe someone who could can fix it.
Reactions: DrDmoney
That is pot metal and better just to replace.
Reactions: JMT and DrDmoney
Back to business. Iā€™m very glad I didnā€™t remove the TCase and split the halves without cleaning it all up and looking for the leak. Iā€™m about 100% confident you can all tell where ATF is coming from.
The thing about those JB speedoheeler O-Rings is theyā€™re crap. They really are too small, but try finding one with the same ID and a wall thickness that is just ever-so-slightly thicker. Every one I try wonā€™t go in the hole. So, I wrapped some megalock (Teflon like material twice around the sensor, then put the O-Ring on and went for a 30 minute drive. Everything is dry now.
So, I cleaned up all the accumulated dirt and grime from the leak that was everywhere. Now I can get back to business with the raised body mounts. Driver side next. That will complete my project for February.
It is replaced now. Once I got it all together I expected the turn signals to work. They did, then didnā€™t. I tore it apart again and used some QD electronic cleaner and air to clean it all out. They worked, they didnā€™t, kept messing with cleaning. They work now, but the cadence of the turn signal is irregular. I cough it up to being 29 years old and poorly maintained. electrical system probably has corrosion. This kid doesnā€™t want to pay me $100ā€™s of dollars to search for electrical gremlins. If they crap out soon Iā€™ll replace his signal switch relay. Itā€™s also a pain in the butt. Oh well, they work mo better than nothing.
Sounds like a bad ground to me.
Reactions: JMT
The replacement part looks like a stamped steel part not cast.
Reactions: JMT
I finished the GenRight Raised Body Mounts yesterday and today. It was a pain using ratchet straps and brute strength to try to get the body mounts to line up. All good now, and my February project is out of the way!
I think my welding is getting better. I still make some bad mistakes like come off the line as you can see in one photo. Fortunately, I only need 1/2ā€ bead along each side. Fix my bad welding if you see 1, 2, 4 or 20 things wrong! I need all the help I can get!
Got something cool in a box and a couple cool hats to go along with it. My oldest daughter already stole the WRG hat and was wearing it around. When I asked later where it was she just smirked and chuckled. I found it hanging on her hat rack in her room. šŸ™„ If she likes it that much maybe I should let her have it. She never asked what WRG meant. šŸ¤£
Got something cool in a box and a couple cool hats to go along with it. My oldest daughter already stole the WRG hat and was wearing it around. When I asked later where it was she just smirked and chuckled. I found it hanging on her hat rack in her room. šŸ™„ I think I should let her have it.
That looks like the box a fairlead comes in.
  • Love
  • Wow
Reactions: Apparition and JMT
Finally broke into the goods. The box looked like I had already gotten into it, and it had, but the reason is I had received the regular hawse fairlead, had to send it back, and it came back in the same box. This is a nice piece. Confident in the anodizing bc I know Blaine doesnā€™t settle for anything less than the best.
I'm a Ray Charles welder like the rest of us, but are your welds hot enough?
