NSG370 to 42RLE Swap
My reverse gear is virtually useless and Advanced Adapters did not recommend any rebuilders or remanufacturers of the NSG370. This transmission was the Mercedes transmission that Chrysler adopted in 2005, seven years after the merger with Daimler-Benz. They were losing money at the time because the minivan market that had revived Chrysler and attracted Daimler-Benz was already being overtaken by the SUV market in the US. At any rate, this piece of shit transmission was put behind the legendary inline 6 (i.e. 4.0). I decided now was the time to swap to an auto because it's a reliable transmission with good rebuild reputation, parts are still available, and most importantly, for wheelin' it's superior to a manual even if the crawl ratio is not great. The big con to this transmission is the 0.69 O/D which can be partially overcome by gearing deep and turning the O/D switch off. That brings us up to speed. I began acquiring parts a couple months ago. They were not difficult to find, though the entire engine harness was very costly. This first post is to simply post up everything you will need to do this swap minus a few tools I didn't list that I considered common. i got a lot of help from others on this forum such as
@mrblaine,
@Jamison C,
@Mike_H, and
@Jezza
White - required
Green - optional but recommended
Red - required for my setup
42rle transmission
Flex plate with stiffener - hopefully comes with the transmission
Torque converter (T/C) - hopefully comes with the transmission
Dipstic/Tube
Auto PCM - Wrangler Fix
Dash harness if you don't have the O/D connector behind the HVAC
Clutch block off plate
Shift Bezel/Indicator PRND21
Shifter stalk and T-handle - 05-06 specific or modify 03-04
Shifter base plate
Auto console bezel
194 Indicator Lamp for Bezel/Indicator
Shift interlock cable
Shift interlock at steering wheel plug (I don't know what these are called but it's silver, has a spring, two screws, and a small odd part)
Shift cable
Auto brake pedal w/connector
Auto starter
Auto transmission cooling lines
Transmission temperature gauge
Auto Radiator
4-prong engine and transmission harness
Torque converter bushing/crank shaft pilot sleeve
Nylon push mount cable zip ties
Engine harness loomtape
T10 torx security bit
ARP 6 flex plate bolts
AC evap and transmission cooling line removal tools
Steering column auto lower bezel
Transmission cooler
Radiator cap
BMB 3/4" Amber LED's
AC Evap
Savvy MUAauto transmission bracket
