B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
I was thinking the TJ might be too skinny to stay out. If it was me I'd still probably try to start up on the driver wall and see if you can walk you pass tire up that first middle rock. It might climb given it has a lot of weight on it. Depends on rock traction. I like experimenting with diff lines and since it's a the beginning you can easily back out and try again. Be careful with Lockers on the rear and throttle. It's going to kick the rear end out if you can't climb.I like it. I just don’t think I’m wide enough to stay driver and keep my passenger wheels on that ledge. These are the spots that I wish I was wider. I still can’t help but feel like if I can stay balanced between driver and passenger and just stay out of that hole that it’s doable. It’s really hard to capture the right perspective with photos. It’s a little wider than it looks. I should have pulled the TJ up to it and took some pics from the top to get a width reference for y’all
