I love these "construction" photos.two Jeeps means two bumpers
the TJ with a Hardrock stubby
and the YJ with an aluminum Metalcloak
Definitely emphasizes the change from stock tire capacity.
Which warrior hoop is that?I cut down the original bumper by 8" and angled the ends so I could install the MOPAR plastic flat end caps. I added a slightly modified Warn winch plate and a Warn VR10,000 winch. I also added a Warrior hoop that I modified to fit the winch plate. I kept the original lights and used Reese hooks.
I guess I dont get the point of a hoop, it just removes the ability to stand on the bumper:motorino:eriodico: when I am working under the hood.
Isnt that what the 8274 is for?It keeps the deer out of the radiator![]()
I was looking at the 07-18 wrangler warrior hoop and wondering if I could make it work on my LJ.
It's listed as a universal hoop so it might work. I bolted mine to a Warne winch plate. I had to fabricate some brackets and weld them to the hoop to make it work.
https://www.justjeeps.com/warrior-p...r-center-hoop-for-universal-applications.html
Thanks for the info. That’s the same part number that Quadratec listed for the JK’s that I was looking at.
I may have to try it and do a little fab work to mount it, and add a couple light tabs.
Do you have any other pics of it mounted? Maybe a side view and a close up view?
Sorry I don't have any close up shots of it and also that I got it wrong above (it's been a few years since I did it). I welded the brackets I made to the winch plate NOT the hoop. The Warn winch plate is the raised version and the hoop wouldn't fit flat on it. I cut a piece of 2" channel iron to match the length of flat iron bases of the hoop. I cut and ground down the channel iron to fit the contour of the winch plate and then welded them to the plate. I was then able to bolt the plate and hoop together.
This pic shows it a bit better (passenger's side as the other side is obscured by the cable). The "wedge" under where the hoop is bolted down is the piece that I made and welded to the winch plate.
I like that. I may do something like that if I don't like my bull bar. I like how you kept the stock bumper but added the stuff and made it look great. If you wouldn't mind when you get a chance, can you take a post a pic looking down, so I can see behind the winch?
Thanks. I'll take a pic tomorrow and post it. One change since the above pics were taken is that the solenoid is now mounted on the winch. I had it under the hood back then. My LJ is covered in snow and it's -24*C and dark right now. I'm in for the night! lol
Does the rear bumper have the DW name plate also? Mine don't have those, and I don't miss them.Just wanted to add pics of my Dirtworx bumper without the front hoop. I also have the rear bumper. Will post a better pic of the rear bumper when I get a chance.
How are the nameplates attached? I also don't really want it on mine.Does the rear bumper have the DW name plate also? Mine don't have those, and I don't miss them.
