I want to say their are nylon bushings in the movable part, so maybe that’s it?Maybe but it looks like there is a path to ground first through the movable part the Exogate to the fixed part through a hinge. You’ve got to insure good conductivity through that path.
OR put a discreet ground wire to the chassis from the antenna mount.
Ive got 6 of these fire ring cables on the farm.Ill make a better video. The mount is attached to the Exogate with two bolts like this:
View attachment 204940View attachment 204941
Okay, so it sounds like my best option is a braided ground strap like this?Tailgate hinges rarely provide an adequate RF ground as required by antennas and a simple ground wire won't either.
It looks like in the bottom pic, the metal ring is facing up against the hex nut? It should contact the mount.
Yes, something like that. I can't stress enough how much more demanding an RF ground is to having an adequate surface area when compared to a simple DC ground which does not require surface area.Okay, so it sounds like my best option is a braided ground strap like this?
https://www.amazon.com/dp/B01M7NP6KH/?tag=wranglerorg-20
On my tractors, the mirrors aren't grounded since they are mounted in rubber. I just took black wire and crimped rings on each ends. Being OCD, I took off the colored connectors and used a little heat shrink so the ground wire is all black.Okay, so it sounds like my best option is a braided ground strap like this?
Yeah, I want to make sure I get a good RF ground as well. So I could just run this braided line from one of the antenna mount bolts to the tub somewhere near the tailgate?Yes, something like that. I can't stress enough how much more demanding an RF ground is to having an adequate surface area when compared to a simple DC ground which does not require surface area.
That’s what I was thinking. I would just have to make sure to remove the powder coating since the hinges are mounted to the Savvy tub armor, which is also powder coated on both sides.I'm thinking go from the back side of your antenna mount under the hinge to one of the exogate to body mounts.
OHM it out and see if the hinge bolts are forming a good ground first.That’s what I was thinking. I would just have to make sure to remove the powder coating since the hinges are mounted to the Savvy tub armor, which is also powder coated on both sides.
I think I need to figure out how to use this ohm meter firstOHM it out and see if the hinge bolts are forming a good ground first.
Me too. Evil spirits in a wire.Electronics just confuse me.
Nor am I!I think I need to figure out how to use this ohm meter first
Electronics just confuses me.
Yes, scrape enough paint or powder coating off from the ground strap's mounting points so the ring connectors are resting on bare metal. The far end of the strap's connector ring should be connected to the tub or chassis.Yeah, I want to make sure I get a good RF ground as well. So I could just run this braided line from one of the antenna mount bolts to the tub somewhere near the tailgate?
The "fire ring" cable antenna end has a metal ring on one side and nylon on the other. The ring has to contact the mount. I cant tell by looking at either picture.Yes, scrape enough paint or powder coating off from the ground strap's mounting points so the ring connectors are resting on bare metal. The far end of the strap's connector ring should be connected to the tub or chassis.
No guarantees this is the fix, I just wish I could be there to verify that antenna connector's orientation. Call me OCD.![]()
This ^^^^^ If you end up using a braid, keep it short - and wide.Something like that but as short as possible. I will speculate that if you just have a short ground strap to wrap around that nylon bushed hinge that you’ll be ok.
Yes!
