Rubicon John
If I wasn’t married I’d ask for picsIf my wife wanted an angry bird grill and 20" spinners, I'd say yes. She's that good!
Exactly where and how big are the holes you used for the drains?Back to the so called "rust". I drilled the drain holes, then blasted the inside of the frame with the pressure washer. Then after it dried, I took the gallon of Fluid Film I had, I sprayed that into the frame. Painted the frame with primer, then black paint. I also plugged the frame holes on the sides of the frame to keep crap out.
I live in Maine where Jeeps come pre-rusted from the factory. What you have isn't rust its rust stains on metal.
Yes, and her claws and fangs are out this week...Are you married?![]()
I drilled where the brackets are welded on for the control arms. If you look at the brackets there is a hole. I was told that since the brackets are welded on either side of the frame its the perfect spot to drill. I used a 3/8 drill I think, I remember it fit right up into the hole.Exactly where and how big are the holes you used for the drains?
Perfect! Thanks!I drilled where the brackets are welded on for the control arms. If you look at the brackets there is a hole. I was told that since the brackets are welded on either side of the frame its the perfect spot to drill. I used 3/8 drill I think, I remember it fit right up into the hole.
In comparison see my photos This is what i found and i thought i looked super hard!! PO put bondo!I bought this 2004 blue LJ and I went over this thing like crazy and everything looked flawless with zero rust. I get home today to take the chrome steps off and I am crawling around under neath again. Except this time I spot rust inside the frame by the front lower control arms...... I should have caught this before but having already purchased this, how bad did I screw up?
2004 LJ 83k miles
first picture is passenger side
Second is driver side
I stuck a scope inside some of the holes but I guess I missed these two.
I will scope around some more later tonight when my neighbor gets home with the scope.
Years ago I had bought a 68 Mustang Convertible, po/someone did a similar patch up on the frame...my bad for thinking I was "expert" enough to check out a know rusting type vehicle. Took a big hit selling it with full disclosureIn comparison see my photos This is what i found and i thought i looked super hard!! PO put bondo!
2004 LJ 83k miles
safe t cap parts are in route. Thanks. When I’m done this Lj will be ready for a whole new life!!Once you get over the "I feel Stupid" phase safteycap is a great solution
PV stand for Pleasant Valley? If so, I'm in Poughkeepsie.In comparison see my photos This is what i found and i thought i looked super hard!! PO put bondo!
safe t cap parts are in route. Thanks. When I’m done this Lj will be ready for a whole new life!!![]()
Yessir. In garage nowPV stand for Pleasant Valley? If so, I'm in Poughkeepsie.
You a member of HV4W.org? If not, you should come to a meeting and join.Yessir. In garage now![]()
Set me up. When’s the meeting? John D a member?You a member of HV4W.org? If not, you should come to a meeting and join.
