Does Yukon hub kit use outer stub axle from a CJ?
I guess I dont know what I would need those for if I already have CJ knuckles. I also have a set of GM 44 knuckles. The 44 knuckles have a longer reach from the center of the ball joint to the center of the tie rod, which would require a longer pitman arm or you do not get a full turn radius. been there, done that on a CJ, I tried to put bigger calipers on the CJ by using the 44 knuckles, I wound up having to get a dodge van pitman and have it reamed.
If you wanted beefier outer knuckles that were flat top to support hi-steer. If not you could just run a stock early style Dana 44 outer knuckle with Dana 44 outer parts with locking hubs.
I was showing that Reid even verifies this "Dana 44 Outer Mod." by stating their Dana 44 outer knucles will bolt onto an early style Dana 30 axle C.
If you wanted beefier outer knuckles that were flat top to support hi-steer. If not you could just run a stock early style Dana 44 outer knuclkle with Dana 44 outer parts with locking hubs.
I was showing that Reid even verifies this "Dana 44 Outer Mod." by stating their Dana 44 out knucles will bolt onto an early style Dana 30 axle C.
Ok, Now I understand what you were trying to get across. Thanks, Tim
