Was the knocking during cold start only or did it remain even after reaching operating temperature? To help distinguish it apart from other knocking we've been talking about.Alright Gents, here’s my update with everything I’ve done so far. My “ticking” sound just recently turned into a loud knocking sound so that’s what made me investigate further.
I removed my valve cover to find the rockers and push rods loose on cylinder 3. All the others were tight and had no play. So I played it safe and replaced all of the rockers and push rods. Sealed it back up and still had the same loud knocking sound.
Next I dropped the oil pan... To find crank shaft bearings 1-6 worn and loose, timing chain loose as hell, and the skirt on piston 2 broken (which is where my loud knocking sound was coming from I’m assuming). So as of now I gotta check to see if cylinder 2 is scored or damaged badly. If it’s not I’ll start putting it back together here over the next couple of weeks.
As of now I’m assuming my ticking sound came from the loose timing chain. However I know that has been replaced by various people on this thread and has still left them with a ticking sound.. with that said I’m still worried about a possible lifter issue... attached are pictures and a video of the timing chain.
Lmk if you have trouble viewing the images.
Sorry to see that happen.
