If I don’t find a Trans within the next 1-2 weeks I’m feeling a rebuild in my future. Are recommendations on where I should get parts?Yikes, that fluid is black and that’s a lot of metal on the magnet.
Sounds like it’s slipping badly, which means you’re gonna have to open it up (assuming by you had enough fluid). It’s honestly not at all hard to rebuild it, and it’s not even very expensive. But I’m more interested in seeing what your drums & planets look like.
Tearing it down is easy and will inform you if a rebuild is even possible. In my experience low fluid won’t cause a slip, it will just prevent it from even going into gear, but I don’t have enough data to say that with certainty. I say that to say that you could try yo put fresh fluid in & fill it up, but I would not expect a different result.
But hey, I’m wrong literally all the time.
30rh are pretty rare on marketplace….but I do have a core in my garage right now. Fancy a drive to TX?
Lived in El Paso for quite a while but prospers about 15hrs for me. A long ways to drive for a little transmission30rh are pretty rare on marketplace….but I do have a core in my garage right now. Fancy a drive to TX?
So all this is assuming you need a rebuild....there's a troubleshooting guide in the FSM that's worth going through. And you're checking the level while running, in neutral?
The rebuild kits I've been using on 32RH also work on the 30RH, but what you're actually going to be shopping for on ebay is a 904 banner rebuild kit. The A904 is basically what we have. the 30RH will have 1 less clutch in a drum, I believe, and maybe only a 3 pinion planet. There are different grades of kits. Some have steels some don't, some have the drum bushings, some don't, some have the kickdown band, some don't, some have the roller clutch, some don't. It's hard to know what exactly you need until you open it up. My first kit I got off Oregon Performance Transmission because they made it easy to shop, but I spent probably 3x what I should have. The last 5 or 6 I've done have been using kits off ebay.
That will cover the frictions, the steels, and all the soft parts. If you need new planet, sun gear, drums, pump, low/reverse band, etc....you'll have to source replacments off ebay. I've had good luck finding what I need there, seems like most everything is around $100 of course. And you're definitely going to want a new torque converter, so budget another $150 for that.
Rebuilding automatics is my jam, if you can stack a set of parts on top of each other and operate a feeler gauge, then you can rebuild an automatic transmission. But I'm also a surgeon — whatever the symptoms are, I'm going to recommend surgery. Your family doctor should do all the preliminary recon before referring you to the specialist.![]()
It doesn’t seem all too difficult but I really don’t think I’d know how difficult it is until I get into there. From what I’ve seen it looks pretty straight forward with some sockets, snap ring pliers, and some common sense.
What kind of kit should I look at getting for starters before even getting into the transmission? Any specific parts I want to try to make sure I get in the kit?
To me, I just really want to learn about any Auto Trans and their operation. A week ago I didn’t know a single thing about automatic transmission and now I’m here researching. I’m really big on continuous improvement and constantly learning. The fact that I can get insights from others with more knowledge makes learning so much easier and exciting.Really understanding this level of operation is my next goal. I can rebuild them blindfolded but I still don’t come close to understanding HOW they work.
I wish, I just need to get my foot in the door first. Enjoying reading the manual and learning from others experiences definitely makes this more excitingPs. I want to try to rebuild one blindfolded, actually. Aside from reading the feeler gauge, I’m pretty sure I can.
So pull that thing out already, and let’s get to the teardown.
@Wildman
Found a Welder around me. With my IRO Mounts and him traveling to me with his equipment (only about 30 minutes) he quoted me $500.
He broke it down:
$400 for cutting out the old Mounts and welding in the new mounts as well as all prep work
$50 for his welding materials needed
$50 for travel and equipment transportation
So a total of $500
The pictures are some of his recent welds. Not sure what a good weld should look like or if I should move forward.
Thoughts??
I'd say that isn't a bad price but I have no idea what things cost anymore. But if you don't have the equipment then paying someone to come do it or taking it to a shop to have it done will cost.
How much would you change someone if you were the mobile welder doing this job??
The things is, I have a little HF Flux Core welder that I could borrow from my great grandfather and all the other equipment but I have never welded anything before and he’s too old to get out to the garage and teach me. This is also something I don’t really want to weld up because it’s an expensive repair if I made a mistake
