Yep I realize the axels are under more load.Do you? So you understand that you are adding more track width to your axles which is adding stress to your factory axles and axle housings...
Also, with those wheels and tires you are severely limiting what your Jeep suspension was meant to do. You have limited your uptravel..and for what?
You wouldnt limit the travel with the right size tires on the Jeep.
Have you regeared your axles for the bigger tires?
17" tires gives me lots of tire options and until I run into clearance problems I will continue to run them.
No I have not regeared, it feels ok to me so far.
I am sure this is not the final final version of my Jeep.
