Telling folks how to do shit wrong sure didn't slow you down about welding, why stop now?The Op wasn’t asking how to drill the hole, he was asking how to drill the hole to a certain depth. I helped him with that.
Only if we get to post heat as well.I say we preheat the tailgate
Step bits are okay. They all suffer from the same problem. The starting bit wears and gets dull long before the rest of the bit so you have to start pre drilling starter holes and now you're back to using a drill bit.A good fabricator makes mistakes, but only once.
Roto- broaches are nice, and the Greenlee step drill bit works well on sheet metal too.
True.Step bits are okay. They all suffer from the same problem. The starting bit wears and gets dull long before the rest of the bit so you have to start pre drilling starter holes and now you're back to using a drill bit.
Unfortunately I’ve done that before. Sheet metal has a nasty way of deforming enough to create threads for a drill bit to ride.Or the bit grabs and punches an outie you can see from the outside. BTDT, didn't like it one bit.
Buddy showed me a neat trick using a split collar and a screw on the outside to clamp on a drill at any depth. Works really really well and keep from punching into stuff like fuel tanks or electronics.To be honest, I have done it myself. I try to be more careful now a days.
And eventually disappearHere's another consideration. Shavings from the drilling operation fall to the bottom inside of the tailgate where you can't get to them. They then rust...
One reasons experts make mistakes is the same reason the have more experience and are experts.....they tackle a lot more crap. A lot more scenarios. A lot of things they've never done or fixed that somebody shouldn't have done.Experts get to be experts through lots of experience. No one gets lots of experience without making mistakes. I make them just like everyone else does, I just make far less. But, I am not an expert on everything, just everything I am expert at.
Put some grease on the drill bit tip to catch those shavings.Here's another consideration. Shavings from the drilling operation fall to the bottom inside of the tailgate where you can't get to them. They then rust...
Hi! I'm a new Jeep owner.
Am I nervous for nothing?
Not sure why ...
Set your drill bits on an old speaker magnet for about 20 seconds before you drill. Has worked for me for years. Just clean it off after and all done!Put some grease on the drill bit tip to catch those shavings.
Since the tailgate has 2 layers with an air gap in between, don’t worry at all! You won’t punch though to the outside unless you keep pushing your drill in.
