Picking up where I left off
What special tools did you get to aid in the wrapping? Squeeges, plastic knives, soapy water?
Looking good! I highly recommend you dump that license plate bracket and mold the plate directly to the tub. I’ve seen no less than a half dozen folks rip that bracket off on a rock and it destroys your plate in the process.
Reactions: AMS417
Yep, I have every intention of doing this.
Reactions: ToddK
is the heat gun mostly needed to wrap around curves? I have tried to wrap a couple items but I was using standard vinyl I had lying around that is used mostly for signs.
Sometimes, yes. You have to tack the wrap down in key areas, stretch, and as you stretch the wrap will usually form to curves. The heat gun is needed in some situations, though not as much as you might think.
How’s the PSC install coming?
I will be getting back to it tomorrow now that my computer is working and I can work on the instructions as I do the install.
Reactions: Apparition
Who can I go to to get spray paint matched to this wrap? I want to spray the little bits that are impossible to wrap (such as the door hinges).
I figure I could bring a spare piece of the wrap in and have someone match it and put it in aerosols. But where would I go to get something like this done?
Okay, I’ll see if I can find a PPG store or similar nearby.
Only use PPG if you want to spend more. There are other automotive paints that are just as good.
I know nothing about automotive paints. What would be another good brand?
Any local body shop/automotive paint supply store should to the aerosol cans for you. Should be plenty of those independent stores in the Phoenix area. For some reason, I want to say NAPA does it as well.
PPG has their color matching computer that can get it close. I'm sure Dupont has a version as well.
Sick rig! This is what my Rubi wants to be when it grows up. Sorry if I missed it, what is the front bumper setup?
