So I have come to a point now that it is definitely time to regear. I am running 35s on stock drivetrain currently. I have a Dana 30/44 mix on my 05 TJ. I am going to go to 4.88 as that is as tall as I can go on the Dana 30. I am also putting chromoly shafts up front.
Starting off, I wheel, but don't really "crawl" I like to explore, and have been in huge rock piles before. While fun, I still enjoy the tight narrow dirt roads. (Probably more than fully "flexing" out) I just want to be capable enough to get home. So far, I have been doing this on open differentials. I have never used a locker, and I don't believe I have limited slip either.
My real question is if I should put in a locker now while re gearing, or would it be wiser to spend that $ elsewhere. I have been pondering this for a while, and can't decide the right mix either. Front selectable/ open rear , rear selectable/open front, rear auto/ open front, or simply rear limited slip... that being said, I can afford the re gear now, and add lockers later still, but figured if I am doing it now, could save a little down the road.
In reality I could afford to do a auto locker in the rear now while I am re gearing. Or I might be able to do a OX locker in front right now.
Any advise either way, or any other ideas?
I am doing this in a shop as I have never done axles and don't think a DD is a good place to learn!
Thanks!
~T
Thanks!
~T
